Hart Parr 40 Resurrection
this thread has 23 replies and has been viewed 6027 times
Old 08-20-2015, 10:21:46 PM
99 SD PSD 99 SD PSD is offline
Default Hart Parr 40 Resurrection
After this machine had slept for 50 years this is how I was greeted when removed the crankcase covers. Why do Mice like Hart Parr tractors so much?
The Following 9 Users Say Thank You to 99 SD PSD For This Post:
Old 08-20-2015, 11:09:37 PM
Default Re: Hart Parr 40 Resurection
They're great tractors.......what's not to like?.......
Old 08-21-2015, 04:01:33 AM
Brothers Clemens's Avatar
Default Re: Hart Parr 40 Resurrection
My little Hart Parr 30 was also full with mice ore mikey mouse dirt and piss and even in the pipes of the cool system.
Becareful with it because it coult bring sicknes to you and your family.
Yuse cloves and wash your hands when you are finish.
Old 08-21-2015, 09:54:10 AM
Mice are disgusting little creatures. Definitely use of rubber gloves and respirator is a necessity. I determined that they're point of entry was the breather elbow located next to the governor. I have it blocked now. When its back together I intend to install a cap with numerous smaller hole drilled in it to prevent further infestation.
The Following 2 Users Say Thank You to 99 SD PSD For This Post:
Old 08-23-2015, 08:49:09 PM
Photo Re: Hart Parr 40 Resurrection
Well, I finally was able to get the engine turn after a year long good soaking of the cylinders with a lot of PB Blaster. No matter how many times I've freed stuck engines it's still a great feeling!!! Now It's time strip down the engine and get this old Girl on the road to recovery!
The Following 13 Users Say Thank You to 99 SD PSD For This Post:
Old 08-27-2015, 10:39:33 PM
Made some more progress. Unfortunately the engine did take on some water. Fortunately not too bad. The mag is out for rebuild. I've got the cylinder heads apart. I'll be needing some new valves and some machining. I expected that though, it is almost 90 years old.
Old 08-27-2015, 11:40:30 PM
I don't know if the 22-40 and 12-24 share the same valves and guides but I AM sure you won't go wrong with H & J Machining if they can help you.......
http://www.handjmachining.com/Custom...st5-7-2015.pdf
Old 08-27-2015, 11:51:57 PM
Alastair Geddes. Alastair Geddes. is offline
I did some big valves a while ago, i had a post on it if you would like to cut the seats yourself.
Here.
http://www.smokstak.com/forum/showthread.php?t=119126
The Following User Says Thank You to Alastair Geddes. For This Post:
Old 08-29-2015, 09:42:07 PM
Yes, Thanks Craig according to my Original H.P. Parts Price list it shows p/n 11772 (OE Part #) Was used on tractor # 70001 (22-40) & up through the H.P. 28-50. Actually I searched the forum & revisited the thread when You Guys did the H.P. 18-36. Thanks again for the info. I will keep this thread updated as time and progress allows.
Old 08-30-2015, 12:47:44 PM
I sent you an e-mail but I did a 12-24 head and used Mack truck valves. They were almost a drop in fit.
The Following User Says Thank You to John Schwiebert For This Post:
28-50 Hart Parr G Willikers Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 03-17-2015 10:24:29 PM
Hart Parr 28-50 Pat Bayer Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 03-02-2015 02:07:18 PM
Hart Parr 18 36 paul midgley Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 02-28-2015 01:42:56 AM
Hart Parr help... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 07-17-2011 09:47:04 PM
Hart Parr 12-24 Fred Milner Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 09-17-2008 06:45:43 PM
