Hart Parr 12-24
this thread has 1 replies and has been viewed 2219 times
Old 09-17-2008, 06:32:55 PM
Fred Milner Fred Milner is offline
Default Hart Parr 12-24
I am working on a Hart Parr 12-24 and need to put oil in the transmission. It tells you to use light transmission oil. On the old 18-32 Case it tells you to use heavy steam oil. I used 600 weight steam oil in the Case and it works good. Now with that in mind and the fact that both tractors came from the same time frame would the Hart Parr need 400 weight steam oil or something like W-140 transmission oil. The final drives on that tractor uses the used motor oil and you keep it drained down to the right level.
What have some of you used in your Hart Parr tractors?
Thanks Fred Milner
Old 09-17-2008, 06:45:43 PM
Default Re: Hart Parr 12-24
Too heavy an oil in there won't spash to lubricate the ball bearings throughout the transmission.
I use 80-140 in all my tractors.......including my 18-36 and the others I used to have. They aren't fussy......as long as the bearings get oil.
Hart Parr 30 Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 11-24-2012 06:27:31 PM
Hart Parr 18-36 Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 08-17-2008 12:20:04 AM
Hart Parr hottube Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 11-11-2005 11:00:29 PM
12-24 Hart Parr Gasengin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 01-14-2005 12:35:56 AM
Hart Parr 28-50 Craig A Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 12-19-2004 11:43:49 PM
