I think I got the wrong manifold for my Onan 10.0CCKAJ/1E
this thread has 15 replies and has been viewed 1574 times
Old 11-16-2012, 07:44:42 PM
DrCharles DrCharles is offline
Default I think I got the wrong manifold for my Onan 10.0CCKAJ/1E
I got a nice unused exhaust manifold for my 10.0 CCKAJ/1E, serial D920459200 (that D might be a 0) and had a fun time this afternoon removing the original pipe-thread mufflers (lots of penetrating oil and a big monkey wrench did the trick). Then I went to put the new manifold on... it doesn't fit! The flanges are rotated at a different angle.
http://i1181.photobucket.com/albums/...n/PB160010.jpg
I thought I might be trying to put it on backwards.. but turn it around and it's even worse.
http://i1181.photobucket.com/albums/...n/PB160012.jpg
Apparently all CCK's don't use the same manifold? What have I got here... the only marking on it is a hand-written "1430" in magic marker.
http://i1181.photobucket.com/albums/...n/PB160013.jpg
Or, it just occurred to me, can the cast flanges (that the manifold bolts up to)
be twisted to a different position or are they part of the head?
thanks for any help. Now I don't have any mufflers
---------- Post added at 05:44 PM ---------- Previous post was at 05:33 PM ----------
Sorry, that's "1450" written on the manifold.
I googled "Onan 154-1450" and it comes up for an exhaust manifold for an NH...
Old 11-16-2012, 07:59:08 PM
Billy J Shafer's Avatar
Default Re: I think I got the wrong manifold for my 10.0CCKAJ/1E
The Flanges don't move. Haven't seen that manifold in a long time.
Old 11-16-2012, 07:59:52 PM
Yep, that's what I got... three of them on ebay right now and the picture is identical
Now, can someone please verify the correct p/n? My 10CCK parts manual shows either 154-0944 or 154-1212 would work, possibly 154-0998. thanks.
Old 11-16-2012, 08:50:28 PM
len k len k is offline
I suppose you could go to a muffler shop and have them custom weld one up for you, looks pretty simple.
Old 11-16-2012, 08:54:14 PM
Gunny Gunny is offline
Made a bunch of them through the years. Pretty easy to do.
Old 11-16-2012, 10:04:11 PM
Bring them the engine, they will likely have various generic flanges, they'll bolt it on engine, bend and weld a pipe on it, now your spacing and angles are right.
Old 11-16-2012, 10:08:03 PM
Yep, make a set of headers for it.
Old 11-16-2012, 10:18:38 PM
Thanks... I know I can fabricate one, or have one made, but I always prefer to buy the factory original part and bolt it on whenever possible (or if it doesn't cost an arm and a leg which is frequently the case for Onan parts).
There is a used manifold on the 'bay right now (starting at $25) which appears to be the dual-ended 154-0998. I'm tempted to bid on it but not sure if it will clear the "Carrying Frame" which mine came with, mounted on an Onan dolly.
(That's an optimistic name, given that it weighs about 400 lb).
Old 11-16-2012, 10:53:37 PM
Motorhead's Avatar
Why not cut the new manifold about 1 inch above the flanges, twist them to fit the bolt holes on the cast manifold and re-weld them up. I bought a new one for my 5.0 CCK and it looks like it was built for a welder.
http://ebay.com/itm/ONAN-EXHAUST-MANIFOLD-154-0513-NEW-/250575311169
I bought it for $45.00 on a "best offer"
Old 11-16-2012, 10:57:54 PM
That would be my thought also. less than an hour with a cutoff wheel and mig welder, bingo!
Onan CCK Manifold Restoration OnanParts Onan Generators 13 05-22-2014 11:47:34 AM
Wrong info on Onan name plate? Sophiedoc Onan Generators 15 02-23-2014 09:28:29 PM
Wrong Forum But Desperate Onan BGE S.Dale Onan Generators 9 09-04-2012 10:17:23 AM
My "new" Onan 10.0CCKAJ DrCharles Onan Generators 11 01-09-2012 10:59:12 PM
Onan Manifold on Welder WildWillie Onan Generators 4 01-28-2010 08:48:12 AM
