Onan 4.0 BFA Project
this thread has 36 replies and has been viewed 1565 times
Old 08-30-2017, 08:58:26 PM
Handyhiker1 Handyhiker1 is offline
Default Onan 4.0 BFA Project
I picked up a new to me project tonight, a 4.0 BFA that is missing s few parts. It needs an intake manifold, carb snd air cleaner housing. It is a low hour unit, less then 100 according to the seller. One of his mechanics took it apart to paint it and got put in jail for DUI multiple times. He couldn't find where the parts were. It was going to be painted red. He also has a 1957 4.0cck that was in process of being painted and torn down. Also missing some parts.
I looked at the tag and it is stamped as a 1R but it does have the 4 leads out of the generator and the diagram under the cover does show 120/240 hook ups.
Billy has offered a manidold so now I need ro find a carb and air filter housung. Here are a few pics.
Here are the numbers.
4.0 BFA-1R716004A
D783335357
ID:	289886   Click image for larger version
ID:	289887   Click image for larger version
ID:	289888   Click image for larger version
The Following User Says Thank You to Handyhiker1 For This Post:
Old 08-30-2017, 09:49:32 PM
Billy J Shafer's Avatar
Default Re: Onan 4.0 BFA project
I have your manifold almost ready to ship. But with the water problems down here. A little slow. I also have the air filter assembly.
The Following 2 Users Say Thank You to Billy J Shafer For This Post:
Old 08-30-2017, 11:13:23 PM
JohnnyC JohnnyC is online now
Those 4.0 BFA's are tough. I tried to kill mine in many ways and failed. Human piss poured down the carb did absolutely nothing to it as well as anything else that I could find (no, I did not poop on it). I ended up giving up and restored it. Good luck with yours.
JohnnyC
New Jersey
The Following 2 Users Say Thank You to JohnnyC For This Post:
Old 08-30-2017, 11:22:17 PM
I think pooping on it would just make it stink, depending on where the poo landed might make it burn just make the neighborhood and you smell like poo...that is if it has the same effect of pissing in a fire..
The Following 2 Users Say Thank You to YellowLister For This Post:
Old 08-31-2017, 04:48:11 AM
No hurry. I am sure you have bigger things to worry about. If you have both pieces, I would really appreciate them. I got 2 new carbs in the parts I bought last weekend but sure enough, they are not for a BFA.
Old 08-31-2017, 08:07:47 PM
Well, good and bad news. I pulled all the output wire off this and just threw it away after finding that stuff on the 12.5 JC. After that I did turn it over with a socket and ratchet just to see how it felt. Almost no compression. Pulled the plugs,and both were almost completely carboned over. There was no gap, just carbon. With the plugs out I could look in the cylinders, yup, lots of carbon!!
I pulled the right head and could not believe all the crap in the cylinder. Below are before and after pics. Tomorrow I will tackle the other one.
I really do believe that this is a low hour unit but I believe it had a rough life. With that much in the cylinders there is no way it has ever been worked very hard. There was no lip in the cylinders and some of the cross hatch is still there. All in all, I think a good cleaning and going over then to find a carb and life will be good.
With the plugs out did hook up a battery charger with start boost and spun her over. The start switch works and after cleaning the plugs, there was spark. Only did it for a couple seconds just to check for spark and if it would turn over.
ID:	289979   Click image for larger version
ID:	289980   Click image for larger version
ID:	289981   Click image for larger version
Old 08-31-2017, 08:16:04 PM
How does the cylinder bores look? See any hone marks? Or smooth as a baby's azz? After cleaning it up and putting it back together, do a compression test. I think I have NEW head gaskets. They are made of composite graphite. I was able to reused my old (non composite) head gaskets. You may be able too, but it you determine that your head gaskets are toast, I will look for my gaskets and send you my new head gaskets FREE if you commit to getting the BFA running.
JohnnyC
New Jersey
The Following User Says Thank You to JohnnyC For This Post:
Old 08-31-2017, 08:32:12 PM
There are home marks in the cylinder. There was some really light pitting on the botom but not nough to worry about. The head gasket looked good. I cleaned it up and it is already reinstalled. The BFA WILL run again. The carbs I have are for a BEG and from what I can figure out, a welder. Might sell them to get money to buy the right crab.
Onan BGE project KPack Onan Generators 14 10-24-2016 03:10:12 PM
New (to me!) Onan 4.0 CCK Project 808Guy Onan Generators 36 02-16-2016 01:27:58 AM
Onan djb project YellowLister Onan Generators 30 04-13-2015 10:06:21 AM
Onan CCK Project B.Ikard Onan Generators 7 02-26-2012 11:26:29 PM
