Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Johnson Outboard unknown model?
this thread has 3 replies and has been viewed 1509 times
Old 04-03-2017, 07:29:27 PM
Wildvortex Wildvortex is offline
Default Johnson Outboard unknown model?
A friend has this outboard she would like me to sell. I can't make our the model on it. Does anyone know the model and year? I believe​ it is pre WW II. I don't know if it runs. Any idea on what it is worth?
ID:	279162   Click image for larger version
Old 04-03-2017, 07:32:13 PM
Default Re: Johnson outboard unknown model?
Forgot to set notification.
Old 04-04-2017, 01:33:00 AM
johnsonseahorse johnsonseahorse is offline
Images: 2
This is Johnson model A 1921/22 to 1924.without the serial I cant pinpoint the exact year.Please read your personal message I sent to you.
Old 11-12-2017, 10:21:46 AM
Outboardguy44 Outboardguy44 is offline
This will prove to be an early 1922 Johnson motor. The signs that give it away as such would be the steel grab bar and tiller handle tubing, as well as the square opening at the bottom of the transom bracket (visible below the hanging board).
if it is a three-digit serial number, it would be worth more to most collectors than a later version.
Johnson got rid of the opening in the transom bracket fairly early in the 1922 production run, estimates put the number of motors with that feature as less than 1000 units.
Hope this helps.
Best,
PM T2
The Following User Says Thank You to Outboardguy44 For This Post:
mid 20's Johnson A-25 outboard Bilbo14 Antique Marine Engines and Outboard Motors 4 02-27-2016 07:58:10 PM
Owner's Guide for '73 Johnson Outboard (Model # 4R73C) whataboutbob Antique Marine Engines and Outboard Motors 0 06-25-2013 10:18:53 AM
Johnson AL(?)70 outboard motor randannie Unidentified Engines 1 08-06-2012 12:13:40 PM
1940 Johnson outboard model ha 15 lohrcharles Antique Marine Engines and Outboard Motors 2 03-18-2012 02:19:33 PM
Johnson Outboard Karl Keefer Antique Gas Engine Discussion 1 07-29-2007 02:05:20 PM
