Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
67 Mercury 50hp Distributor and Coil Wire
this thread has 12 replies and has been viewed 1157 times
Old 01-25-2018, 02:59:23 AM
yokilla yokilla is offline
Question 67 Mercury 50hp Distributor and Coil Wire
hi all
first time on forum, need some help bench testing three post rectifier, two yellow posts and one red in the middle of the yellow posts, I need to know how and what to test this with??? and how to test the two wires that are coming from the stator? Ive seen nothing for this year on how to bench test them,,,,any help will be appreciated.
Thank you
yokilla
Old 01-25-2018, 12:30:36 PM
Harry's Avatar
Images: 312
Default Re: merc. 1967 50hp elect. testing
https://www.google.com/search?q=merc...nt=firefox-b-1
Old 01-25-2018, 02:28:47 PM
Thank you harry for the info. this will help a lot, does anyone know how to bench test. the recitifier, and stator????
thank you
Old 01-25-2018, 05:38:48 PM
sorry,,,i found info. that will help. thanks again.
yokilla
Old 01-25-2018, 08:54:59 PM
Question 67 merc 50hp distributor and coil wire
hello,
how to do remove the coil high voltage wire to the distributor????does it only screw at the distributor end and just pull out of the coil? or does both ends screw out?
Old 01-25-2018, 11:05:01 PM
cobbadog cobbadog is offline
Default Re: 67 merc 50hp distributor and coil wire
If there is no obvious screw holding the High Tension lead in place then yes it just unscrews.
Old 01-26-2018, 01:27:35 AM
Default Re: 67 Mercury 50hp Distributor and Coil Wire
I will remove the coil tomorrow, and try to unscrew it. I know it unscrews form the dis. cap. I could not find anything on the coil end. I saw a video on checking spark using the switch box and coil. I do not want to break the coil high voltage wire trying to remove it by just pulling on it.
Old 01-29-2018, 12:13:02 AM
Question Re: 67 Mercury 50hp Coil Wire and spark plug check.
hello,
Was able to pull coil wire from coil end, hard but came out.
Got motor back from dealer, not running.
New plugs were installed, # champion L76V???? will this work with this motor??
I believe plugs should be QL82C or L82C.
what do you think?????Thanks
Old 01-31-2018, 02:48:41 AM
johnsonseahorse johnsonseahorse is offline
Images: 2
Hi.merc usualy runs a surface gap plug.L76v sounds about right.Surface gap plug has no curved arm that the plug that goes to the electrode.As for a rectifier,has nothing to do with a spark.All the rectifier does is charge the battery.Keep in ming it only charges only what it uses.It not a battery charger.It wont charge a complete dead battery.Its not that strong.If u have spark issues start looking at condition of distributor cap and rotor.The contacts have to be clean!!I hope this helps u.
Old 02-03-2018, 12:42:24 AM
Cool Re: 67 Mercury 50hp Distributor
hello all,
Having a bad time locating parts for this motor.
Question: Will a 74 50hp merc. distributor thunderbolt, work on a 67 merc. 50hp?
will they interchange.
thank you
I H Cub 3 position light switch with coil distributor need a wiring diagram . Old wrenched Garden Tractors / Mowers / Scooters 2 12-03-2016 01:38:39 AM
Wisconsin VH4 Ignition Wires, Coil & Distributor Cap Hugheski Wisconsin Engines 4 11-14-2014 11:13:01 PM
5.0 CCK distributor coil Robert S. Onan Generators 1 05-08-2009 05:59:57 PM
Tractors equipped with Atwater Kent distributor and coil Randy Reysen Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 04-01-2009 07:43:59 PM
1980 Mercury 50hp carb ? Mercury Man Antique Gas Engine Discussion 1 05-17-2005 02:57:41 PM
