WIFI Booster (Amplifier)
this thread has 7 replies and has been viewed 1229 times
Old 01-24-2018, 08:33:44 AM
squidtrap squidtrap is offline
Default WIFI Booster (Amplifier)
SO- got cable guy to fix most of my problems but i still have one.
we hang out in the back room which is about 40' from my router and around 2 turns. i works fine in my seat (usually) but where my wife sits its 90` from where i am so the signal is much weaker.
directly across the room and in the kitchen is an outlet where i could put a booster which would b a straight shot to her and it has a good signal. did a speed test there and its the same as other places in the house.
can anybody recommend one that they might know is good. looking at them they range from 15.00 to 120.00 the computer guy at work said there are plenty that will do the job as its only about 20' to her seat, thanks Ed.
Old 01-24-2018, 09:35:54 AM
LCJudge LCJudge is offline
Default Re: wifi booster (amplifier)
I bought one at Staples and I think it was in the $30 range. It does the job fine and enabled me to put WiFi in my shop which is about 100 ft from the house. In some cases you're paying for the name rather than the product.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 01-24-2018, 10:53:47 AM
Harry's Avatar
Default Re: WIFI Booster (Amplifier)
Tommy, I need to do the same thing, house to shop long haul. What brand and model booster did you get? My ASUS router almost makes it, especially if the computer in the shop has an external antenna, but a cell phone or notebook is in the dark. Is the booster in your shop or is it nearer to the router?
I put a new mini-split in the room over the shop and a WIFI connection would give me full monitoring and control of that unit.
(See our Terms of Service)
Old 01-24-2018, 11:51:03 AM
I don't need one so I can't offer any good data. But click on these reviews and see what they say.
http://www.toptenreviews.com/compute...i-fi-boosters/
Old 01-24-2018, 06:23:01 PM
Judge- i had called my local staples and they said they only carry 1 and it was 120.00 but had no complaints or returns. a little steep for 1 dead spot.
looking at a d link one for like 40.00 that has real good ratings. also no problem to return if it does not solve my problem.
Old 10-29-2018, 06:34:39 PM
AngolaGravely AngolaGravely is offline
Old thread, But I have some info to help.
Look into DD-WRT. It's a generic router firmware that loads onto like millions of cheap routers.
one of the firmware settings is "WiFi Repeater". it's easy to flash to a cheap router, easy to set up and once set up, does not need anything but a power source. It can run standalone at a fringe area.
Plus, if you want to play with settings, I've found lynksys radios in the routers are default set to 35% broadcast power. DD-WRT allows you to crank that to 100%.
THIS DOES REPLACE YOUR STOCK FIRMWARE AND CAN BRICK YOUR ROUTER IF NOT DONE CORRECTLY.
The good thing is, if it still fires up, you can flash your routermaker's firmware back to it and recover it 99% of the time.
https://dd-wrt.com/
Click here and see if your router will work.
https://dd-wrt.com/support/router-database/
The Following 3 Users Say Thank You to AngolaGravely For This Post:
1955 Farmall 300 Torque Amplifier Nate Bolduc Antique Farm Tractors 14 09-21-2017 06:40:15 PM
Johnson Ignition Amplifier vs. Car Coil lilgreen Antique Marine Engines and Outboard Motors 4 04-07-2011 07:58:51 PM
CCK Vacum Booster B.Ikard Onan Generators 3 03-18-2008 12:29:44 PM
CCK Vacuum booster Ted_Cool Onan Generators 2 02-01-2006 04:21:21 PM
Mag booster?? Ihorse Hit & Miss Gas Engine Discussion 11 08-15-2005 02:09:29 PM
