Hot Air Engines
Essex Hot Air Engine
this thread has 6 replies and has been viewed 1395 times
Old 05-17-2019, 10:42:01 AM
Brian.P's Avatar
Brian.P Brian.P is offline
Default Essex Hot Air Engine
I bought this engine years ago it was missing the disk and the connecting rod
need to make a base and burner and age the rod runs not bad just have to time it a little more
would it have had the water tank at the end for cooling
thanks to woody sins for the measurements
https://youtu.be/U-GOCfoEPsQ
The Following 7 Users Say Thank You to Brian.P For This Post:
Old 05-18-2019, 10:35:33 AM
Brian.P's Avatar
Default Re: Essex Hot Air Engine
Made this little stand this morning and hooked up burner
Need to put slotted screws to hold it down and a couple of other things but more less ready to show
https://youtu.be/kUKWO3EcT1w
ID:	335062   Click image for larger version
The Following 6 Users Say Thank You to Brian.P For This Post:
Old 07-20-2019, 06:42:19 PM
Brian.P's Avatar
I added this tank a couple of weeks ago
it ran with out it but should run at a lower heat on hot days
this one never had a tank as there are no holes for the screws and no grove in the flywheel for a fan
when I have the time I will be adding something to run off it
The Following 4 Users Say Thank You to Brian.P For This Post:
Old 07-28-2019, 09:49:43 AM
deverett deverett is offline
Seeing your original engine, it just goes to show what a good job MyfordBoy did of copying the design.
I've got a turntable for mine, but haven't hooked it up yet.
Dave
The Emerald Isle
Old 09-29-2019, 07:47:39 PM
Brian.P's Avatar
He does great work
I ordered the turn table casting today will have it ready for next year
there isn't many little hot air engines here the 2 shows I had at this year always had someone looking at it
will be nice with the turn table with some old toys on it .going to make a 24 to 30 '' wood top
Old 10-07-2019, 11:54:56 AM
Originally Posted by Brian.P View Post
He does great work
If you give me your email address, I'll send you a picture of my engine hooked up to the turntable. I can't attach a picture directly here.
Dave
The Emerald Isle
Essex Hot Air Engine Magneederson Hot Air Engines 3 01-14-2015 10:48:56 PM
essex engine ken lundberg Hit & Miss Gas Engine Discussion 1 11-09-2013 05:40:59 PM
Essex Hot Air Engine Mike Shaffer Hit & Miss Gas Engine Discussion 6 08-16-2012 01:54:36 AM
ESSEX Engine by P.T. Legare. Denis Rouleau Hit & Miss Gas Engine Discussion 12 11-26-2009 01:09:06 PM
Essex engine (updated) Mike F Hit & Miss Gas Engine Discussion 9 06-06-2006 10:12:18 PM
