Welding Shop
Hobart DC 200 A stick welder. Old
this thread has 1 replies and has been viewed 1934 times
Old 03-06-2014, 02:20:25 PM
lajs lajs is offline
Default Hobart DC 200 A stick welder. Old
I need help with finding a replacement Rheostat. OHMITE 8.25 Ohm. Ser No 5305
This is an old machine coupled to a Wisconsin 2 cyl gas engine.
I contacted Galco - They want $1000!! The welder is probably not worth that.
Can they be rebuilt?
I have pictures of the Rheostat.
Can anyone help.
Old 03-08-2014, 05:45:25 PM
dkamp dkamp is offline
eMail NOT Working
Default Re: Hobart DC 200 A stick welder. Old
It can probably be rebuilt- you'd need to find someone who has ni-chrome steel wire of appropriate size for the rheostat.
Another way to do it, and it's rather crude, but very effective... is to find 8 or 9 1-ohm resistors of sufficient power level, and wire that in place, with a jumper wire, and just select connection points between resistors to give you the adjustment... if you need finer adjustment, put 8 1-ohm resistors in series, with one 1/2 ohm and one 1/4-ohm resistor, and use two jumpers... one to bypass the 1-ohm resistors, and one to bypass the half or quarter-ohm values.
Old hobart welder cub102 Welding Shop 7 01-30-2012 05:44:54 PM
Hobart GR-303 Welder-Gen Help Jim Tremble Generators & Electric Motors General Discussion 7 01-27-2011 11:42:49 AM
How does an AC stick welder current control work? systemloc Welding Shop 1 09-18-2009 11:54:43 PM
old hobart welder Dan Potter Welding Shop 1 06-16-2007 01:54:52 PM
Help: 6 cylinder 3KW generator/stick welder rcmule76 Welding Shop 0 01-14-2007 09:48:29 PM
