1982 Dayton 3000 Watt Generator Model #w178
this thread has 9 replies and has been viewed 2659 times
Old 10-25-2015, 03:02:56 PM
WornBoots WornBoots is offline
Default 1982 Dayton 3000 Watt Generator Model #w178
Hi All,
Due to very little info available, I thought I would try here for help.
I have contacted Grainger Supply as suggested by other posts and have not received a response, that was Thursday so it may take a while.
Dayton Electric Mfg. 3000 W 120/240 ph1
Model# #w178 Ser# not readable,
Briggs and stratton 8 HP.
190412 - 1782 - 02 - 820317
This Genset was mounted on a Telco line truck, it was intact and complete.
After rehabbing engine, carb and tank it fired right up and was producing power.
An occasional Blue flame / spark shot from the inside of control end, after opening I found the Terminal Board / Brush holder cracked and weathered.
Along with one of the leads hitting the rotor and arcing, also a couple of the resets broken.
If anyone has info on this unit, parts list, part numbers etc. it would be a great help for me and any others searching........ Thanks' Dan
Sorry, The Model Number is 3W178
Maybe a Moderator can edit ?
Model# 3w178 Ser# not readable,
Old 10-25-2015, 10:15:37 PM
GADavis GADavis is offline
Default Re: 1982 Dayton 3000 Watt Generator Model #w178
Many of the Dayton generators were made by Winco. I doubt you will get any support much from Grainger. I have a 3 Kw made by Winco and an 8 Kw Dayton that is a rebadged Winco. Post a picture or two and maybe somebody can I D it for you.
The Following User Says Thank You to GADavis For This Post:
Old 10-26-2015, 02:12:23 PM
Default Re: 1982 Dayton 3000 Watt Generator Model 3W178
Ok here a the pics of the overall unit, sorry for the quality.
Thanks GADavis, and I hope this helps.......
ID:	237544   Click image for larger version
ID:	237545   Click image for larger version
ID:	237546   Click image for larger version
Old 10-26-2015, 06:16:13 PM
I received a response from Grainger Support, they did have a Operation and Parts List in PDF.
The part I need is X65RF-026 Brush holder. and according to the support response the unit was made by DESA ? found a desa online but no luck with part #
Here is a little better pic of board / brush holder
If worse case I could make one from fiberglass but rather find a replacement.
Old 10-27-2015, 08:45:48 PM
ClydeM ClydeM is offline
The 3W178 is covered in the Intertec Small AC Generator service manual 2nd edition 1986 (pages 14-16) but doesn't show much useful information. In one diagram they show the brush holder as part number 4, but other then a wiring schematic and hints on cleaning the slip rings there is not much there.
The Following User Says Thank You to ClydeM For This Post:
Old 10-27-2015, 11:42:28 PM
I appreciate your response, and letting me know what you found.
DESA went out of business a while back, but some of the old stock might be around still.. I am checking into that and playing the waiting game.
Everything else checks out well, would be well worth replacing or making a new holder / board.
Thanks' Dan
Old 10-27-2015, 11:46:46 PM
That looks like a Pincor unit maybe?
Old 10-28-2015, 12:41:55 AM
Pincor gbrf-30h2 or GBBT series comes very close, but after some digging I found the same Brush Holder part # in the parts list along with the same breaker #s. .... Let me guess that pincor is NLA as well ??
Thanks' for the ID, and I will keep looking for a supplier Dayton - DESA - Pincor
Brush Holder X65RF- 026 (X65RF026)
Breakers 22616-001 15 A
Breakers 22616-004 30 A
Old 10-28-2015, 01:08:37 AM
circuitman circuitman is offline
give ebay a shot, they may have something.
The Following User Says Thank You to circuitman For This Post:
Old 11-10-2015, 11:12:43 PM
Default Re: 1982 Dayton 3000 Watt Generator Model 3w178
Well after many emails and calls, its a no go on the brush holder / board replacement.
After removing it (in three pieces) it was cleaned and inspected !
I super glued the board back together first, then took some light (.25 OZ)fiberglass cloth and some 30 Min Epoxy. Laid strips both horz & Vert. wrapping around from front to back and side to side, once set it made a very solid repair. the thickness of the board was increased a bit, but allowed the brushes to better align on the slip rings.
Also some of the reset breakers available at a local electrical supply worked just fine, and look almost identical to originals.
I will put a few more hours of run time on it, but so far its working well.
Now onto a 80's Powermate............ Thanks All' Dan
The Following User Says Thank You to WornBoots For This Post:
Dayton 8000 watt Bigredcherokee Generac Generators (SEARS, etc.) 10 11-12-2017 03:00:26 PM
Dayton 2500 watt, 120/240, 3600, need model number generator jim Generac Generators (SEARS, etc.) 4 05-07-2014 04:55:07 PM
Hyspec 3000 watt tinkerman2012 Generac Generators (SEARS, etc.) 5 11-15-2012 02:49:36 PM
Problems with Dayton 3300 Watt Generator Model 3W178E DCS 2K Generators & Electric Motors General Discussion 10 09-14-2011 09:48:06 PM
Dayton 3500 watt gas powered generator turbolover Garden Tractors and Mowers 1 09-14-2011 09:12:22 AM
