PE-75-B Homelite generator
this thread has 4 replies and has been viewed 3958 times
Old 03-07-2004, 04:54:38 AM
Heath Daily
Default PE-75-B Homelite generator
Just acquired an older generator with the following markings:
Signal Corps Power Unit PE-75-B Serial Number 1107 Order No. 594-CHI-41 Built by Homelite
I was hoping that I might find some information as to it's origin, age, and original usage. Seems free and still compresses good, so I'll probably try to fire it up in the next couple of days. Is there any good place to look for a manual for this unit? Found quite a few on E-bay but who knows if they're the right ones????? Anything I should pay attention to before I attempt to start it? I'd hate to break it through ignorance.
Thanks!
Old 03-09-2004, 04:56:48 AM
Heath Daily
Default Re: PE-75-B Homelite generator
Got it apart slightly. Other than the fuel system being filthy, seems to be in pretty solid condition. The sparkplugs have a cast resin???? insulator that sits over the plug, but inside the stainless covers. One of these has been broken. Does anyone know where I can get another. Or what they are made of. I could probably turn one out on a lathe if I knew what material to use.
Old 03-13-2004, 04:54:59 PM
Russ Hughes
The PE-75 series generators were World War II Army vintage. They were pretty rugged units. They were rated at 2.5 Kw, but would put out as much as 4.0 Kw for a while. The output voltage under normal operation was around 130 volts. This seems a little high, but when the generator was located some distance away from where the power was being used to reduce the noise level, the loss in the long extension cord was made up by the higher voltage. The engine ran at 2100 RPM and with the reduction through the belt drive, the generator ran at 1800 RPM for 60 cycle power. The one that I and several of my Ham radio friends had years ago all had Briggs engines powering them. Anyway that's basically what I remember from the few manuals we had available at the time.
Old 03-14-2004, 12:39:59 AM
Heath Daily
Got her back together again, except for the plugs which no one seems to be able to cross-reference. I built up the insulators previously mentioned with "magnum steel" a 2 part epoxy in a stick form. Filed it down, and it looks pretty good. Hope to fire it up as soon as I can locate plugs.
Thought I'd share a picture, so here it is. Would you believe this was rescued from the local dump!
Old 03-14-2004, 05:22:13 PM
Heath Daily
oops, musta got cut off
Homelite Generator Old Chris Hammerbeck Generators & Electric Motors General Discussion 8 02-25-2016 02:14:42 AM
Homelite Generator Bart Generators & Electric Motors General Discussion 2 09-10-2008 09:22:01 PM
Homelite generator 8HY-1 DannyT Generators & Electric Motors General Discussion 0 07-25-2005 12:03:05 PM
old homelite generator marksman Generators & Electric Motors General Discussion 4 05-03-2005 09:39:17 PM
old homelite generator steve lux Generators & Electric Motors General Discussion 1 04-28-2003 04:03:53 PM
