Welding Shop
Carftsman Stick Welder
this thread has 7 replies and has been viewed 1275 times
Old 09-22-2017, 11:25:33 AM
johndeereboy1962 johndeereboy1962 is offline
Default Carftsman Stick Welder
Hi All, I have an old Craftsman Stick Welder that I need to locate new cables for. The Ground Lead won't be a Problem but some dim-witted kid renting space in my garage either threw my electrode cable out or one of his friends stole it. I will get the model# up later but are there any outlets to re-place cables for these older units? It's got to be from the 60's but I hate having to discard a good unit over a cable. Thanks for your time to read my thread Friends
Old 09-22-2017, 01:28:01 PM
Deerlope Deerlope is offline
Default Re: Carftsman Stick Welder
I have found good deals on ebay. I had to put the ends on and the electrode holder but that is not bigy. I like using 1/0 cable.
Old 09-22-2017, 05:42:37 PM
Seafarer12 Seafarer12 is offline
I assume it has the removable cables and not the hard wired ends? I have an old Wards 230 amp welder and they have lenco connectors on them that just push in. Ebay has the best price on cables I have found. 1/0 is pretty heavy for a little cracker box. I usually run 2 on most of my stuff. I don't like the heavy leads, most of the time I don't need them.
The Following User Says Thank You to Seafarer12 For This Post:
Old 09-22-2017, 10:46:00 PM
circuitman circuitman is offline
if you have one like mine you have one permanent cable & one that plugs in.a hi & low port. i bought one at an auction, crack heads cut off the cables. welding leads & power cords.i bought some brass rod & am having some one make me one.
Old 09-23-2017, 02:38:18 AM
I use the 1/0 then the last 6 feet before the electrode holder I reduce it back to #4. Works for me.
Old 10-18-2017, 11:34:43 AM
Thanks guys for the input and Circuitman you are absolutely correct one is removable and the other is a hard wire cable.
Old 10-18-2017, 08:45:35 PM
if that is the case , i got my wire from ac/dc supplies on ebay.used #4 gauge. used a copper lug to attach it internally, bought some brass rod stock to turn down to make a plug for the front. i used a piece of .050 brass stock, you have to turn it down with a taper to go in the plug. then drill a hole off center in the back for the cable then drilled & tapped for a set screw. had a friend do this for me. then i'm going to use a piece of heat shrink tubing for my insulation. then buy a ground clamp & electrode holder, for your ends. made mine 15 feet. works great!!
Old 10-18-2017, 08:52:17 PM
just another thought had about $35 in wire. $7 for a ground clamp another $8 for an electrode holder from harbor freight.so maybe a little less or over $50.
Eutectic Magna Tran 301 stick tig welder ramsay Welding Shop 10 08-31-2017 09:24:27 PM
Hobart DC 200 A stick welder. Old lajs Welding Shop 1 03-08-2014 05:45:25 PM
Depression era welder, still works good. Sell as a welder or antique? therrera Welding Shop 0 08-30-2011 10:09:54 PM
How does an AC stick welder current control work? systemloc Welding Shop 1 09-18-2009 11:54:43 PM
Help: 6 cylinder 3KW generator/stick welder rcmule76 Welding Shop 0 01-14-2007 09:48:29 PM
