Steam Engines
Small Factory Built Steam Engine with Unusual Cylinder
this thread has 3 replies and has been viewed 1017 times
Old 11-24-2017, 09:36:15 PM
Default Small Factory Built Steam Engine with Unusual Cylinder
I've had this engine for several years laying on my basement floor. It had a broken casting and needed cleaning up. I started working on it last week. This is the one that I ask about markings on the bolts that I never saw before. I got the crank mount welded , painted , and remounted. Some of the other parts were cleaned and painted. The cylinder and valve body are one casting are one piece. The valve operates by way of a push rod moving back and forth to a lever turning a shaft. I got it running smooth on 6 lbs. of air. B&S 2 1/2" X 2 1/4" with a 9 1/2" FW. There some casting numbers that start with B. While working on it I could tell that it came from something else and was taken off and mounted on this board. It's not a model and with the casting numbers and unusual cylinder , I was hoping that someone could identify it. Ron
ID:	296830   Click image for larger version
ID:	296831   Click image for larger version
The Following 2 Users Say Thank You to Ronald E. McClellan For This Post:
Old 11-24-2017, 09:53:00 PM
Default Re: Small factory built steam engine with unusual cylinder
Here are some better pictures of the cylinder. Ron
ID:	296837   Click image for larger version
Old 11-24-2017, 10:52:11 PM
Joe K Joe K is offline
Possibly started life as a steam pump manufactured by George F. Blake? (Hence the "B" seen on various cast parts?)
I have seen but not taken note of similar simplex pumps which embody a hand-lever about where the valve gear protrudes the valve chest - this to allow an operator to get the valve gear "off center" when the pump inadvertently stops at mid-stroke - and cannot be restarted.
See https://books.google.com/books?id=ga...mpany.&f=false for more on Blake.
Blake before the turn of the 20th century merged with L.J Knowles (aka Blake - Knowles Pumps) who were eventually absorbed in the Worthington dynasty.
I have seen several successful conversions of steam pumps into steam engines, including a duplex engine (no dead centers) done using a duplex Worthington Pump.
Joe K
The Following 2 Users Say Thank You to Joe K For This Post:
Old 11-25-2017, 07:48:00 PM
Default Re: Small Factory Built Steam Engine with Unusual Cylinder
Blake must have made items other than pumps. The crank and the bearing caps have B numbers. The only parts that don't look original are the piston rod slides. I found markings on the bottom of the cylinder today. I had to take the cylinder off to be able to read them. Pat'd , Aug. 24 , Nov. 16 , 1880. Ron
Oscillating Cylinder Small Steam Engine Toesmack Steam Stationary Engines, Traction Engines 5 10-17-2017 03:19:41 PM
Can you tell me who built this 2 cylinder engine? Denis Rouleau Steam Stationary Engines, Traction Engines 2 10-31-2014 06:49:43 PM
Alamo built engine with unusual carb. Denis Rouleau Hit & Miss Gas Engine Discussion 4 11-25-2011 10:43:38 PM
Most unusual factory option that you have seen... Casemaker Steam Stationary Engines, Traction Engines 26 02-14-2011 02:46:29 PM
Small Unusual Steam Engine leenpatatcomcastnet Unidentified Engines 7 05-05-2010 09:17:13 AM
