2 HP Vertical Famous ?'s
this thread has 5 replies and has been viewed 2227 times
Old 08-19-2005, 03:56:48 PM
Mike Smith's Avatar
Mike Smith Mike Smith is offline
Question 2 HP Vertical Famous ?'s
Working on two 2 hp Famous engines. One is ser.# KA15027 (1909) and it does not have a throttle control lever only a flat arm that is L shaped and comes around and bolts up in the same place as the lever would. The other is ser.# KA28417 (1912) and it does have the throttle control lever. Is the 1909 missing it's lever? Did all 2 hp verts. have them? If not then what year did they appear? I would love to see some close ups of this area and see examples of both.
Thanks in advance,
Mike
Old 08-19-2005, 10:59:02 PM
Default Re: 2 HP Vertical Famous ?'s
The speed control levers are alittle later sometime around 1910.Rob
Old 08-20-2005, 07:13:05 AM
Coolhand Luke Coolhand Luke is offline
Hi Mke,
My 2hp Famous (pump engine) is a 1908 and it does not have the lever. I saw two others at a recent show that both had the lever. If I remember correctly they were both after 1910. Also, they both had brass-body fuel pumps, where mine is cast iron.
Luke
Old 08-20-2005, 07:51:51 AM
Mike Smith's Avatar
OK thanks, What's the purpose then of the flat bar or bracket that comes around and just stops that is bolted to the same place where the speed control lever is on the 1912? I don't see its purpose. Can you post a pic. of yours in this area.
Mike
Old 05-13-2013, 06:37:02 PM
3d-craft 3d-craft is offline
Hi,
trying to find dimension for cooling tank, for IHC Famous 1910. It came without it, so we want to rebuilt one. Any help?
Old 05-13-2013, 09:26:10 PM
Skip Landis Skip Landis is offline
Is this what you need? skip
Name:	skips picture 083.jpg
IHC Famous 3HP vertical stevenkd5017 Hit & Miss Gas Engine Discussion 6 09-26-2012 08:09:13 PM
IHC famous 3hp vertical stevenkd5017 Hit & Miss Gas Engine Discussion 5 08-25-2012 10:25:16 AM
2 hp vertical Famous? Johnny T Hit & Miss Gas Engine Discussion 20 01-10-2008 10:20:40 PM
3hp Vertical Famous LW Antique Engine Archives 14 06-03-2004 10:39:03 PM
IHC FAMOUS VERTICAL Joe LeBlanc Antique Engine Archives 2 06-05-2002 09:12:22 PM
