Welding Shop
Help with an old welding machine!
this thread has 7 replies and has been viewed 6105 times
Old 01-10-2009, 11:38:16 PM
anakell anakell is offline
Default Help with an old welding machine!
I recently purchased an old welding machine and wanted to see if anyone knows anything about it. I am posting photos and would appreciate any reply. 200 amp Hammett closed circuit AC. I have not been able to find any others on the internet.
Name:	welding 008 small.JPG
ID:	46423   Click image for larger version
Name:	welding 018 small.JPG
Old 03-19-2010, 10:29:46 PM
rusted rusted is offline
Default Re: Help with an old welding machine!
Good to know there are at least two of these. I inherited a Model 250 from a friend who passed away. He used it for about thirty years that I have known him. Has anyone else used one or is using one? I have a couple of questions...
Old 03-20-2010, 09:10:09 AM
Holland501 Holland501 is offline
Question Re: Help with an old welding machine!
OK, I'll ask. What sort of questions do you guys have?
Old 03-20-2010, 03:38:02 PM
Thanks for asking, Holland501! My main question deals with the switch on top marked "off-low-med-high". I know the amperage is selected by plugging the cable in to the desired hole (40, 60, 90, etc.) so what am I changing when I flip the switch from medium to high. I never paid much attention when Wes was welding and now I wish I had. Also, would the duty cycle be figured about the same way as a more modern welder? That is the more the amps the less the duty cycle? Thanks for any help or opinions!
Old 09-29-2012, 11:15:19 PM
Just bumping this up to the top in hopes that some of our new readers might have info or opinions.
Old 09-30-2012, 11:52:09 AM
Jan4CMF Jan4CMF is offline
It would seem like the top switch would be a fine tuning switch (rheostat ) just easier then moving the cable lead. That's just my gues.
Jan
The Following User Says Thank You to Jan4CMF For This Post:
Old 09-30-2012, 12:24:37 PM
That's my guess also. Duty cycle doesn't seem to be a problem... windings on this thing must be huge! I am not a good enough welder that I can tell the difference between low-medium-high or maybe the switch is only making the on-off function. This thing suits my abilities well. It's old and so am I!
Old 10-01-2012, 09:24:40 AM
Some transformer type welders had high and low outputs which gave higher and lower open circuit voltages to suit different electrode types. Typically the higher striking voltage was required for low hydrogen and other special type electrodes. I think they probably switched in a few extra turns on the secondary. May be able to confirm this with a voltmeter. Combustor.
The Following 2 Users Say Thank You to Combustor For This Post:
Welding rod Chris J Welding Shop 7 08-17-2008 10:22:53 AM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
Smith Welding Machine DannyP Welding Shop 3 11-19-2007 11:30:39 PM
The Good Machine Company / American Roads Machine Jeff Smith Hit & Miss Gas Engine Discussion 0 04-15-2005 11:10:28 AM
Welding Matt Fretwell Welding Shop 23 10-12-2003 07:35:59 AM
