Posting pictures
this thread has 16 replies and has been viewed 1609 times
Old 02-28-2009, 12:02:07 PM
Dennis K. Nash Dennis K. Nash is offline
Default Posting pictures
Trying to figure picture posting.
Old 02-28-2009, 03:07:21 PM
OldironPhil's Avatar
OldironPhil OldironPhil is offline
Default Re: Posting pictures
Hello, when you hit post new thread you will see below the reply box MANAGE ATTACHMENTS, click on this. then go to BROWSE, decide where your photos are. Documents ect. You normaly would have your photos in my documents on your computer. When you find your photo hit UPLOAD. This should do it. I beleve it is best to save your photos as JPEG. Phil
Old 02-28-2009, 03:33:51 PM
Rag
But, how can a pic be added to a reply?
Old 02-28-2009, 04:14:55 PM
Same way, look under the post reply box when it apears. Go down to manage attatcments. it is in the ADDITIONAL OPTIONS box. I put a photo there. Phil
Old 02-28-2009, 08:07:55 PM
Harry's Avatar
http://www.smokstak.com/forum/showthread.php?t=40589
There is a FORUM in Smokstak that NO one ever reads!
How to use this web site:
The Following User Says Thank You to Harry For This Post:
Old 02-28-2009, 08:22:53 PM
CLips221's Avatar
CLips221 CLips221 is offline
Who reads instructions before the fact? Round here we always try figuring it out before admitting defeat. Thanks for the "how too" anyways.
Craig Lipscomb
Keep Coming Back. It Works If You Work iT!!
Old 03-01-2009, 12:21:52 AM
Maybe the problem is with my computer, I am doing it exactly the instructions indicate. The upload meter takes an extremely long time to run, when it does complete, I still have no attachment.
Old 03-01-2009, 12:26:11 AM
Harry's Avatar
When that happens, your picture is most likely too large for processing. You need to reduce it down to a reasonable screen size for web use. Many new cameras take huge photos so that they can be printed on paper.
(See our Terms of Service)
Old 03-01-2009, 12:39:12 AM
That is more than likely the problem, I pulled up the properties and it is a jpeg, 4.33meg. But I have no idea how to reduce the size to post it.
Old 03-01-2009, 01:45:01 AM
Harry's Avatar
I think 4.0 is the limit.
This one might be useful to you, unless software came included with your camera.
http://irfanview.com/
Old 03-01-2009, 04:33:14 AM
cham cham is offline
4.33 MBs is definately your problem.
I've had problems getting just over 2 MB images to upload.
If you can get your images reduced you should be able to get it done.
Old 03-01-2009, 12:00:48 PM
I think I've found it! Wow, I'm becoming a technition!
ID:	49583   Click image for larger version
The Following User Says Thank You to Dennis K. Nash For This Post:
Old 03-01-2009, 01:37:38 PM
rusted rusted is offline
Cool mule, Dennis!
Old 03-01-2009, 02:25:51 PM
Brickman's Avatar
Brickman Brickman is offline
good job dennis , where did you get that little buggy at ? is it military or 4x4 motor, weight ,rear stear, transmison ,how fast
thankyou ron brown in central illinois ,wants one of them
Old 03-01-2009, 02:55:08 PM
That is an M274 1/2 ton 4X4. It is Vietnam era military. It is 4wheel stear, full time 4 wheel drive (all four wheels locked together) with a 14hp two cylinder engine. All specs. can be found at militarymules.com. It's a three speed trans with hi-low range. This model is aluminim (previoue models were magnezium). It is goverened to 25mph, and has no suspention. There is a dealer in Peoria Il., that is his e-mail address above.
Old 03-01-2009, 03:01:18 PM
Have not seen one of those carts in a long time, remember them running arount the air bases and some LZs. That hoist is not original is it. Forgot what they were called, but they were pretty quick. THANKS. Phil
Old 03-01-2009, 05:25:57 PM
The nickname is a Mule. The hoist is from Harbor Freight. They are sold with a hand crank winch, I put a 2000 lb. electric winch on it, also from H.F. As a test I was able to pick a 550 lb Quad runner off the ground with no type of outrigging on the Mule.
Posting Pictures (Please Help) Jeff Blaney Computer, Camera and ISP Problems 2 07-25-2007 05:08:52 PM
posting pictures Mark Congden Antique Engine Archives 18 12-22-2004 12:05:40 PM
Posting pictures Al Steppich Antique Engine Archives 15 02-18-2003 10:57:40 PM
POSTING PICTURES RICK Antique Engine Archives 1 03-30-2002 04:58:58 PM
Posting pictures(again) Jim Antique Engine Archives 4 01-06-2002 10:26:55 AM
