Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Johnson Ignition Amplifier vs. Car Coil
this thread has 4 replies and has been viewed 2621 times
Old 03-29-2011, 11:51:12 PM
lilgreen lilgreen is offline
Question Johnson Ignition Amplifier vs. Car Coil
Hello great minds. My older brother gave me a 1968 Johnson 55 hp about 10 years back and it's been sitting in the shed since. Well I went out the other day to do something with it and found the mice had the same idea. The amplifier is shot and some of the wires are too. I can splice the wires and fix that, but about the amp is a different story. Have any of you heard of replacing the amp with a car coil and resistor simply because for a new amp it would cost about $300.
Old 03-30-2011, 09:18:41 AM
Harry's Avatar
Default Re: johnson amplifier vs. car coil
They must place a bunch of stuff in that box that most likely can't be replaced by a simple coil and points. It must be a capacitance discharge ignition. You might look for one on eBay, but watch for the seller's feedback if you are a new eBay user.
(See our Terms of Service)
Old 03-31-2011, 07:08:20 AM
grub54891's Avatar
Default Re: Johnson Ignition Amplifier vs. Car Coil
How about a picture of the amp and motor?
(see above $269.95)
Old 04-06-2011, 10:55:40 PM
vern0n's Avatar
vern0n vern0n is offline
If you can get a schimatic of the wiring, you could probaly come up with some home grown set up. Is it points ignition?
Old 04-07-2011, 07:58:51 PM
noodles noodles is offline
I have a few motors out back and a large amount of oem parts get me a part number, I can get you a good deal if I have a used one.
Noodles
Interesting coil find: The Chief Super Ignition Coil packrat56 Hit & Miss Gas Engine Discussion 3 09-14-2007 09:16:19 AM
Fuller & Johnson Ignition Question Tom G Hit & Miss Gas Engine Discussion 4 10-09-2006 10:34:57 PM
Fuller & johnson DE Buz coil ignition TTYoder Hit & Miss Gas Engine Discussion 2 12-20-2005 07:49:01 AM
32V ignition coil Nick Generators & Electric Motors General Discussion 5 03-07-2005 12:17:25 AM
Ignition coil Marty Antique Engine Archives 28 08-05-2002 09:47:45 PM
