Dayton 3500 watt gas powered generator
this thread has 1 replies and has been viewed 3321 times
Old 09-13-2011, 11:50:00 PM
turbolover turbolover is offline
Default Dayton 3500 watt gas powered generator
HI I have an old Dayton power plant with a Briggs engine model #23AF8 generator model#1W517 3500watts,115/230v,AC with the operating manual,s what I.am looking for is the engine h.p ratting.These manuals and the data engine plate do not show this info.
Old 09-14-2011, 09:12:22 AM
K D Redd K D Redd is offline
Default Re: Dayton 3500 watt gas powered generator
The engine is about 9 HP. It uses the Briggs Magnematic magneto which is KNOWN to have coil problem. The coil problem to the newbe LOOK like a carb problem. You can data the manufacture of the engine by looking at the Briggs serial number list posted in the technical info section of http://www.smokstak.com/library/tech...nical-data-25/.
Kent
Sears and Roebuck 3500 watt alternator identification help bmilbourn Generac Generators (SEARS, etc.) 11 04-21-2017 01:00:50 AM
Problems with Dayton 3300 Watt Generator Model 3W178E DCS 2K Generators & Electric Motors General Discussion 10 09-14-2011 09:48:06 PM
Sears companion 5000 watt generator needs generator unit daytonakid Generac Generators (SEARS, etc.) 1 05-17-2010 04:21:46 PM
Powerwise 3500 watt generator Richard W. Generators & Electric Motors General Discussion 6 11-30-2009 09:21:22 AM
7kw Wisconsin powered Dayton generator msjanket Generators & Electric Motors General Discussion 0 09-07-2006 05:07:33 AM
