Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
Model Stroke v/s piston dia.
this thread has 6 replies and has been viewed 1448 times
Old 01-15-2015, 11:58:39 PM
GarysToys GarysToys is offline
Default Model Stroke v/s piston dia.
I just picked up a small Craftsman 109 metal lathe and a milling table and vice for a drill press. I want to start building some small model engines.
I want to start with a flame licker type. Is there any formula for the diameter of the piston, versus the stroke for these engines. Also, how do you size the flywheel and it's weight?
Also most of the models I have seen are made from aluminum. I have a lot of steel and cast iron around that I would like to use. Is there any reason I can't use these materials for the piston and cylinders.
Any help would be appreciated.
Old 01-16-2015, 12:08:58 AM
Capt...John Capt...John is offline
Default Re: Model Stroke v/s piston dia.
Cast iron pipe works good for a sleeve. Steel for crankshafts. What size of engines are you building?
The Following User Says Thank You to Capt...John For This Post:
Old 01-16-2015, 12:35:52 PM
Jamesk815 Jamesk815 is offline
Smile Re: Model Stroke v/s piston dia.
You want to have a little weight to your flywheels . There are several places where you can get plans, for these engines, they are advertised even on this site . That well give you a good idea where to start. Just remember when building one, that friction is your worst enemy. Your not going to be able to do much milling on the drill press either.
Old 01-16-2015, 01:24:23 PM
Turn of the century it was common to see bore x 2 equaled stroke on a 4 cycle engine. Later engines brought it dowm to 11/2 to one ratio. Most modern engines are about 1 to 1 bore to stroke.
Old 01-16-2015, 03:56:55 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
A lot of builders have told me they preference 1 1/4" bore and stroke. With a larger bore you may add stroke for looks. With lessor bore you need to keep stroke square, so 1 1/4" bore by 1 1/4" stroke.Firing chamber dictates compression. A 3/8" crank shaft is also less likely to bend. You can also use 3/16" bolts . 1/8" 5/40 is too small. A 5 3/8 " plus flywheel will give better momentum for slower running.
Every thing just seams simpler in this scale range.
The Following User Says Thank You to Matthew Guy Clarke For This Post:
Old 01-16-2015, 04:15:02 PM
Doug Oldenburg's Avatar
Doug Oldenburg Doug Oldenburg is offline
Hey Mat........Speaking of castings & such, did you ever get around to casting those parts that I ordered last July 26 from you ? I know you said it would be awhile, so just checking again.
"So Much Iron & So Little Money"
Old 01-16-2015, 06:30:38 PM
Heins Heins is offline
If you are going to build the flame licker engine, heat will travel faster in aluminum than cast iron. That is what makes the flame licker engine run.
JAP 34cc model o 2 stroke pedrodepacas Small Air Cooled Gasoline Engines 2 05-17-2014 09:22:46 AM
J.A.P Model 34 2 stroke. Info needed. Rex Wellendorf Small Air Cooled Gasoline Engines 3 11-06-2011 07:49:04 PM
Model Marine Engine, 2 Stroke Air cooled, need spark help! Evan Hale OConnor Scale Model Engineering 3 04-30-2010 02:23:37 AM
Clinton 3 hp 4 stroke no serial or model number ElvisPresley Small Air Cooled Gasoline Engines 4 11-22-2009 03:39:37 PM
Model 2-stroke...almost done. NAR Scale Model Engineering 4 04-01-2008 09:05:38 PM
