Witte MD 12 project
this thread has 25 replies and has been viewed 2624 times
Old 06-20-2017, 12:17:14 PM
Grigg Grigg is offline
Default Witte MD 12 project
Last week I picked up second Witte Diesel to play with.
This one came with a 230 volt 10hp DC motor/generator which I'm not real sure what to do with.
It was setup to be cooled by city water, total loss.
Attached are a couple pictures of fetching it.
This evening I'll unload and see about starting it.
The story goes it was provided with or purchased to run a machine tool that required DC power, in a school setting. The only paperwork I have are 3 student papers/reports from 1947 detailing how to setup and run the tool, including one paragraph roughly describing how to adjust, hand crank, and start the engine and generator.
The machine tool is long gone. Next the engine was used for various mechanical engineering labs apparently infrequently until some years ago, now not run in 5 or more years. For that purpose I presume the cylinder was drilled and tapped for a valve into combustion chamber. I'm not sure what exactly was used for pressure sensors, indicators or the like. All I have is the valve attached, a couple spare valves, a pressure relief fitting, and it has thermocouple in exhaust and magnetic tone wheel bolted on end of crankshaft.
A few years ago the engine was removed from it's original installation and put in storage. I picked it up from there and it seems outwardly to be in fine shape. Missing an air cleaner but does have 1/4" screen over the inlet, keeps out the big chunks!
Grigg
ID:	284815   Click image for larger version
ID:	284816   Click image for larger version
The Following 3 Users Say Thank You to Grigg For This Post:
Old 06-20-2017, 12:28:07 PM
Vanman Vanman is online now
Default Re: Witte MD 12 project
Nice that you were able to save Both machines! Hopefully their tinkering with the engine hasn't irreparably damaged it?
Too bad the machine tool it powered is gone.
LOVE the Direct Current motor! May we have a shot of its nameplate?
Keith
Old 06-20-2017, 12:39:36 PM
Keith
Sure, attached
The Following User Says Thank You to Grigg For This Post:
Old 06-20-2017, 04:03:43 PM
Exclamation Re: Witte MD 12 project
The tag you posted says 'MOTOR', not generater. Does it indeed make power if it is driven, or was it used to motor over the engine? Interesting find! With the fuel shut off, the engine would have made one hell of an air compressor (valve on the head???).
Old 06-20-2017, 04:22:23 PM
That shunt motor would make a quite good generator, especially since it has interpoles.
Interesting thought about that poor engine being turned into a compressor. Certainly seems possible.
By the nameplate, on the motor, I'd guess it to be of later manufacture than the engine.
Keith
Old 06-20-2017, 09:46:10 PM
Try this video.
---------- Post added at 09:46:10 PM ---------- Previous post was at 09:44:16 PM ----------
Well.. that might not have worked and not sure why, try this link instead
https://youtu.be/moGzmNPAODY
The Following 5 Users Say Thank You to Grigg For This Post:
Old 06-20-2017, 10:29:56 PM
Chuck Moss's Avatar
Chuck Moss Chuck Moss is offline
Well done Grigg. That certainly didn't take you long to get going! It looked to me that it fired on the first time through compression. In any case you sure look to have found a treasure.
Old 06-21-2017, 08:58:45 AM
Thanks,
It has a lot of original paint and should clean up nicely. Apparently it hasn't been all that long ago it was running and therefore wasn't any trouble to start again.
Oil was only on lowest end of dipstick so opened crankcase cover and poured oil on the moving stuff and filled the front sump. Eventually it settled in to be over full and running out dipstick hole by a few quarts, should have that sorted out now, thankfully figured it out last night before it made a mess.
It was definitely running the Direct Current "motor" as a generator and had been from at least 1947, presumably from new in early 40's I guess. To my eye the motor/generator does look suitably old.
What can I do with 230V DC? Or wonder about cost and inefficiency of an inverter to make it into AC?
Old 06-21-2017, 11:22:10 AM
You could always slow down the engine and / or use a field rheostat to reduce the voltage to 115 or so. Did the generator come with its field rheostat? Without it, that one will have to be turned quite slowly to get 115 volts.
Then you could run light bulbs and quite a number of vintage appliances.
Keith
Old 06-21-2017, 12:45:19 PM
You can buy 230V light bulbs.
Witte CD 12 generator project Grigg Vintage Diesel and Oil Engines 44 06-07-2017 03:26:47 PM
New Project Cito2490 Onan Generators 16 02-12-2017 09:43:33 PM
Witte Diesel with Witte generator Griz Vintage Diesel and Oil Engines 11 11-11-2012 06:13:20 PM
Project: Welding Cast Iron Witte Head David M. Lyon Antique Gas Engine Discussion 10 04-28-2011 04:41:29 AM
New Project K D Redd Generators & Electric Motors General Discussion 6 08-28-2009 02:19:43 PM
