Floating vs Bonded Neutrals
this thread has 25 replies and has been viewed 21693 times
Old 03-22-2018, 02:53:24 PM
DieselBound DieselBound is offline
Default Re: Floating vs Bonded Neutrals
I'm no electrician, not by a long shot, but...
My understanding is basically what armanh states. The thing that most people seem fixated on is grounds when in fact it's the neutrals that are the most critical (or so that is how I've read it- Mike Holt's site is extremely valuable).
I have my generator's neutral unbonded, passes through to my main electrical panell (which has an interlock kit).
Old 03-22-2018, 03:49:49 PM
Power Power is offline
Then, in my opinion, you have it right. I think Mike Holt is good, but he is occasionally wrong!
Old 03-22-2018, 04:00:31 PM
Email NOT Working
Maybe personally he gets something wrong but I can't point to any wrong info on the site or else they would change it. Can you point to something you disagree with? I think he is one of the most carefully thought-out sources of information out there.
Old 03-22-2018, 06:50:18 PM
zuhnc zuhnc is offline
Interesting conversation. Is it not true that one can have as many GROUNDS from the generator frame to earth (ground rod, for instance) as one wants (this would be the GREEN wire), but ONLY ONE ""neutral to ground" connection (this would be the WHITE wire), at the main entrance panel? None of the load wires (L1, L2, N) are in any way connected AT the generator TO the generator frame; only at the "neutral to ground" connection (or bond, if you prefer). zuhnc
Old 03-23-2018, 08:34:17 AM
stretch67 stretch67 is offline
Canadian Electrical Code Book 2018.
Rule 10-212 and 10-214.
See attached photo.
This is for grounding.
I am still reading about the bonding.
Hope you can read it. I took photo with phone.
Old 03-23-2018, 09:10:40 AM
More Info.
Don't know if it will help or not. It's a dry read the code book is.
If anybody want more info from the CSA 2018 Electrical Code Book PM me and I will try to get you the sections you want.
Floating Pumps Bill Sherlock Garden Tractors / Mowers / Scooters 0 08-13-2007 02:07:52 PM
Unswitched Neutrals on Two Gensets Jim Davis Generators & Electric Motors General Discussion 6 08-10-2007 01:12:21 PM
Is Portland floating????? Norm Antique Engine Archives 3 05-20-2000 10:51:08 AM
