Onan JB Points
this thread has 6 replies and has been viewed 1363 times
Old 10-01-2015, 10:23:14 AM
terry smith terry smith is offline
Default Onan JB Points
Does anyone know the correct NAPA part number for points that will fit an Onan JB? I would like to keep a spare set on hand
Terry
Old 10-01-2015, 01:16:08 PM
BRae's Avatar
BRae BRae is offline
Default Re: Onan JB Points
I wanted to do the same as you Terry. I kept looking on ebay and searching the web. sometimes they seem hard to find try to google Onan: 160-0002 as for a condenser, they can be had but can sometimes be expensive. a decent quality condenser from an automobile will work it should be .3 mfd. Others on here have had the same points in their JB's for years with no problems. A very reliable system if properly installed.
Old 10-01-2015, 07:54:35 PM
Ed Stoller Ed Stoller is offline
Hi neighbor,
One option is to use the old points and a Point Saver, overnightsolutions.com, which is a transistor like switch for the coil. This way the points only see about .3 Amps and 12 Volts. The point saver also has a LED static timing light.
Ed Stoller, New Fairfield CT.
Old 10-01-2015, 09:10:31 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Terry
Napa #7-01035 replaces 160-0002 these also fits cck ,cckb points.
Now the condenser for the JB Has the tab on the end to fasten with screw not sure what Napa number would be I know the onan number is 312-0116 value is .3MF 300DC check with napa take that number with you there is an older fellow at my NAPA and he is good at running cross reference for me.
The Following 5 Users Say Thank You to Onan Dan For This Post:
Old 10-02-2015, 02:52:35 PM
BRae's Avatar
This looks like a suitable replacement for the 312-0116 condenser.
http://www.oreillyauto.com/site/c/de...0790&ppt=C0218
The Following 2 Users Say Thank You to BRae For This Post:
Old 10-02-2015, 03:14:33 PM
sdowney717 sdowney717 is offline
Napa Condenser is
Champion: H-8
NAPA, Points: 7-01035
NAPA, Condenser: 7-01312
Brigg's, 68768, part, for the plunger seal
Good for CCK, MCCK too.
Plunger seals just seem to last forever.
The Following 3 Users Say Thank You to sdowney717 For This Post:
Old 10-03-2015, 07:14:07 AM
Thanks for the great information. I stopped at NAPA on my way home from work and picked up a set yesterday. Now its off to the tractor show today in the pouring rain....
Onan 5.0cck-3cr-13j onan generator, oil in points bubbasz1 Onan Generators 5 03-23-2014 10:32:43 AM
Onan 4.0 BFA looking for points. TTslim Onan Generators 1 11-15-2012 06:18:24 AM
Onan points $$ how do i set the gap? scooby143 Onan Generators 23 08-07-2012 08:48:42 PM
Onan CCK Points Cruiser Onan Generators 4 04-18-2012 07:35:39 PM
need onan points set mark b Onan Generators 2 09-21-2003 05:32:38 PM
