Onan 2.5 AJ 1p/114k weight
this thread has 10 replies and has been viewed 751 times
Old 09-27-2015, 09:28:13 PM
paridgerunner paridgerunner is offline
Default Onan 2.5 AJ 1p/114k weight
What in the "He??" is inside this thing. Man O man the guy that built this dolly put the wheels on the wrong side I never felt a single cyl. engine weigh this much. I need to check for 12v armature for starting. but will run with rope start definatly a screamin 3600. tag says 12v so maybe It can be wired elec. start but there are no cables now will have to dig in when I get time.
Old 09-27-2015, 09:52:45 PM
yellowlister yellowlister is offline
Default Re: Onan 2.5 AJ 1p/114k weight
there be copper and iron in them onans.. and lots of it
http://www.smokstak.com/forum/showthread.php?t=80597
the old sales literature says about 130 pounds.. yes.. those wheels need to be moved slightly behind the center of the engine on the genny side
nice gens for 3600 rpm.. can you post some more pics?
Old 09-28-2015, 06:45:21 AM
Kpack
Look in the service manual 924-0502 for weights .
Old 09-28-2015, 08:29:29 AM
scoops scoops is offline
lol. that aj is the lightweight of the group.
if you think its heavy, try lifting a cck
Old 09-28-2015, 10:29:31 AM
JohnnyC JohnnyC is offline
...... or my portable 800 lbs 15.0JC. Takes 2 people to roll it if the ground is not level and / or smooth. If it gets away from you, it will take out a small car upon impact.
JohnnyC
New Jersey
Old 09-28-2015, 10:59:56 AM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Hey neighbor you got to eat your Wheaties for breakfast if you want to move these onan s around you and I are not to far from each other I have a little 1000 watt DW Onan and son generator it is cast iron about 200 lbs also then I have a JB 7.5 it weighs 475 lbs I see you have some toys in your collection on your profile. I been trying to locate a nice ole vintage 12. 5 DJC add to the collection.
Old 09-28-2015, 09:02:19 PM
Yes I have a cck also and remember how heavy it was when setting it up but I thought that AJ with just a single cyl. was really heavy on the engine side. Hey Dan hows it goin neighbor my profile needs updated that Onan green has got me a couple of times more since I wrote that profile. Thanks all for the litiature
---------- Post added at 09:02 PM ---------- Previous post was at 08:48 PM ----------
Why DJC isn't that deisel ? I like natual gas for emergency no storing fuel that goes bad and hard to start after carb sits long. Also waiting in line at fuel stations could get old. But maybe you don't have natual gas where you are. Have a good one John
Old 09-29-2015, 07:24:58 AM
Kevin K Kevin K is offline
That's me, no natural gas. Probably never happen in my lifetime. But I do have enough tanks to hold a winters worth of #2 fuel oil, with a healthy safety margin. So in my case a diesel makes sense. My 3.0DJA will power the heating system, refrigerator, some lights, and the TV. If I need to pump water, microwave food, or whatever I start a gasoline generator. I'm still looking for a reasonably priced DJB or DJC.
Old 09-29-2015, 09:11:41 AM
Onan Dan's Avatar
Really I am trying to locate a diesel onan DJC for the son in law and family he has a total electric home and no natural gas he does have a diesel tractor so he would have fuel for a DJC me I have natural gas and run my onan on it plus I have onan s run on gasoline.
Old 09-29-2015, 02:55:25 PM
I guese I am luckier then I realize having nat. gas. I have a 30EK and 5cck on nat. gas and a couple of small gasoline units. I have a main 10 inch nat gas transmission line right a way that goes through my yard over 100lb pressure I was standing near it with my dog one day when one of the old pipe couplers let go. POW ! Scared the Sh?? out of me and the dokg we ran like he?? it took 4-5 hours before they could get it shut down the whole valley was full of gas. It blew a 10' hole in the ground. All the gas co. trucks where here and they let there engines running on there trucks and I asked Don't you think you need to shut them down and they just laughed and said the mixture has to be just right to blow and I said OK ?
Old 09-29-2015, 03:07:07 PM
Onan Dan's Avatar
Pa ridgerunner do not believe everything those guys tell you I worked over 30 years in the oil and gas field anything is possible I have seen some explosions of natural gas caused by a little spark from static had a bailing machine back fire and set well on fire HOT DAM any way natural gas is the way to go for fuel way cheaper than petro or lpg
What's size and weight of ONAN JB len k Onan Generators 44 08-14-2015 07:38:01 AM
Onan MDJF Weight Daverepair Onan Generators 5 04-19-2011 05:38:17 PM
Onan 4CCK Oil Weight c east Onan Generators 5 04-14-2011 09:37:59 PM
Rotor weight on an Onan 30.0 DDA Frank T Onan Generators 2 03-16-2010 10:05:23 AM
Dimensions and weight of onan ojc? Joe Stewart Onan Generators 1 01-06-2006 02:15:20 PM
