need help decoding this MCCK
this thread has 6 replies and has been viewed 503 times
Old 10-02-2015, 07:32:18 PM
Indy1K Indy1K is offline
Default need help decoding this MCCK
Hi Folks,
I am picking up another ONAN MCCK 6.5 but am confused by what the guy is telling me from the plate.
Here is what he is telling me.
Model # reads MCCK-30P/2268F, Serial # 0170217367
As you can see, the plate is very hard to read.
Can someone lookup the serial number and tell me what this is? I think it is a propane unit.
Thanks,
Kevin
ID:	235902   Click image for larger version
ID:	235903   Click image for larger version
Old 10-03-2015, 07:01:13 AM
Kevin K Kevin K is offline
Default Re: need help decoding this MCCK
Let me make a guess on the model number:
6.5MCCK-3CR2268F
-3C = reconnectable 120/240 or 120 volts only
R = remote start (P = Portable/pull start)
Serial# 0170217367
01 = January
70 = 1970
The Following 3 Users Say Thank You to Kevin K For This Post:
Old 10-03-2015, 08:31:14 AM
MBB MBB is offline
Here are the engine data sheets. I believe Kevin has it correct as far as model. It would be gasoline carb.
The Following 3 Users Say Thank You to MBB For This Post:
Old 10-03-2015, 10:25:28 AM
Man, you guys are good!
I am picking this on up for parts. I will use the heat exchanger, the two pumps and the solenoid. The rest I will part out.
Since you guys have the data, can I please ask for a decode on my Genset?
Here is what I have.
MCCK 6.5kw 1A/1E S/N 1072511577
Thanks fellas,
Kevin
Old 10-03-2015, 11:01:23 AM
MBB MBB is offline
Here you go.
The Following User Says Thank You to MBB For This Post:
Old 10-03-2015, 05:41:14 PM
So, what does re connectable mean? Sorry for my ignorance.
Remote start is good because the boat has the remote panel. But if it is a P, that would mean pull starting. Not Good. I thought these models had a winding that acted as the starting winding.
Old 10-03-2015, 06:06:45 PM
MBB MBB is offline
In your case it means its capable of 120/240v 240v or 120v only . In the case of a 12 lead as on for instance a JB it would mean any number of voltages single phase or three phase. Other wise if it were a 3R it would only be the voltage it was built for.
Gen set wireing/ decoding Minicoopman Onan Generators 11 10-16-2014 09:33:13 AM
Onan # Decoding for a 15.0 JC jeff85machinist Onan Generators 4 08-29-2014 08:24:19 PM
Need Help Decoding Briggs 6B Name Plate Briggs Man Small Air Cooled Gasoline Engines 6 07-11-2014 05:40:04 AM
Decoding help needed MDJE FLracer Onan Generators 3 05-04-2010 11:54:27 PM
Help needed decoding BergmanJ Onan Generators 3 09-17-2008 07:31:30 AM
