Onan Parting Out Thread (Used Onan Parts only!)
this thread has 575 replies and has been viewed 46496 times
Old 01-26-2017, 02:58:35 PM
preskitaz preskitaz is offline
Default Re: Onan Parting Out Thread (Used Onan Parts only!)
Looking for Tri Fuel or propane Carburetor for JB. or if someone has a spare adaptor they dont need...
Old 01-27-2017, 03:42:34 AM
Motorhead's Avatar
Good luck on the tri fuel carb. Kinda the proverbial Hens Tooth.
The Control panel
and gauges of my
7.5JB
Old 01-27-2017, 08:24:25 AM
Yeah i realize its a shot in the dark but I got to try. Im trying to figure out how to adapt the current carb to tri fuel. I figure that would be an easier route. Just need to make a vacuum port for the regulator (easy part)and figure out where to place the venturi for the propane (difficult). I know they make kits for couple hundred $ but that takes all the fun out of it. Im also looking at other tri fuel carbs and maybe fabricate an adaptor for that.
Old 01-27-2017, 10:24:08 AM
Ray Lynch Ray Lynch is offline
Jim 's thread about this may help.
Ray
https://www.smokstak.com/forum/showthread.php?t=144397
The Following User Says Thank You to Ray Lynch For This Post:
  #225
Old 01-27-2017, 04:52:20 PM
Crankpot Crankpot is offline
I'm still looking for a vacu-flo fan scroll (air exhaust duct) for a DJB.
Also looking for a late model exciter stator coil for a YD head.
Old 01-27-2017, 10:59:29 PM
vdrive vdrive is offline
If your needing the fan scroll cover. Make one, it's really not that hard to do. I made one complete in about 6 hours. Using just a mig welder jig saw and handy grinder along that a drill for the bolt holes. Just measure out the hole locations and draw it out on card board. Use the blower housing for bolt hole locations. I'll see if I still have the templet I made laying around.
Vdrive
The Following User Says Thank You to vdrive For This Post:
  #227
Old 01-30-2017, 06:22:08 PM
Paso One Paso One is offline
What parts should I save from a 4.0 CCK 3CR 12018R
that could be used for a 6.5 NH 3CR 16004P as spare parts??
Any usable parts in the gen head, as I think I will need to go into that soon
The rest could be made available for anyone needing used parts.
Old 01-30-2017, 07:00:54 PM
Leon N. Leon N. is offline
The answers to the questions raised in post 223 can be found in the Onan manual 967-500 along with pictures!!!
  #229
Old 01-30-2017, 07:49:27 PM
I looked at manual 967-500 ??? is there a parts interchange manual??
Old 01-30-2017, 08:15:59 PM
Parts interchange manual? I am not aware of one. I believe some folks have successfully modified a gasoline carburetor to accept gaseous fuel. Not sure if the author of this thread is aware of the fact that the older Onan J line gasoline-only equipped carburetor engines utilized different part numbers for many functionally equivalent internal parts. Why, you may ask? Because back in the 60's gasoline contained lead where as natural gas or propane obviously did not.
Onan 12.0 DJC parts tim berkemeier Onan Generators 3 09-21-2011 09:11:12 PM
Onan parts Karl Onan Generators 1 04-17-2008 10:22:27 AM
Online Onan Parts Sales-or at least a parts number B.Ikard Onan Generators 3 06-21-2007 07:07:12 AM
Onan cck parts JDavid Onan Generators 1 03-14-2007 10:17:16 AM
Parting out engines thread Handlebar99 Antique Gas Engine Discussion 19 03-27-2006 09:44:37 PM
