Onan CCK wiring
this thread has 2 replies and has been viewed 2905 times
Old 06-23-2008, 10:54:37 AM
sam c sam c is offline
Default Onan CCK wiring
hello to every one. i have a 4cck3cr/12018r ser h750968617,
it's missing wires, and some are cut, i can make it turn over but dont want to go futher without a wiring diagram. ( oh the magic smoke from the pc board)
a peek into the plug holes shows a lot of carbon, i saw a post that spoke of sea foam to remove carbon, don't know what it is or if it works. the plugs and tail pipe show it has been running very rich, iam going to run it on propane will clear its self of the carbon?.
many thanks for any help sam
Old 06-23-2008, 01:23:19 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Onan CCK wiring
If you PM me, I can supply you a wiring diagram for your Spec. R CCK.
Bruce in alaska
The Following User Says Thank You to BTPost For This Post:
Old 06-23-2008, 01:33:06 PM
John A John A is offline
Default Re: Onan CCK wiring
Sam,
The LP Gas will clean it out after you run it for a while.
Its clean burning.
The byproducts of lp gas complete combustion are water vapor and carbon dioxide.
John
The Following User Says Thank You to John A For This Post:
Onan 12.5JC wiring diagram djackman Onan Generators 28 07-18-2017 01:45:36 PM
needs some help with onan 3mdsp wiring mikeinnh Onan Generators 11 01-16-2007 09:05:26 PM
Wiring Onan CCK J Gambrell Onan Generators 2 01-28-2006 12:12:31 PM
wiring diagram Onan W2C werfymmot Onan Generators 15 10-31-2004 04:04:54 PM
help on Onan 2-cyl wiring ken phillips Onan Generators 0 10-25-2003 03:06:54 PM
