Extension rim identification
this thread has 4 replies and has been viewed 1377 times
Old 05-29-2015, 11:57:57 AM
turbo's Avatar
turbo turbo is offline
Default Extension rim identification
I recently came across these in a scrap pile, I think they fit a Moline universal. The lugs are marked UT5373. They are 51 1/2 inches in diameter. Thanks
Name:	IMG_0977 (480x640).jpg
ID:	226478   Click image for larger version
Name:	IMG_0980 (480x640).jpg
ID:	226479   Click image for larger version
Name:	IMG_0984 (480x640).jpg
Old 05-29-2015, 04:26:26 PM
HBurk HBurk is offline
Default Re: Extension rim identification
I bleve Moline Universal is correct.
The Following User Says Thank You to HBurk For This Post:
Old 05-29-2015, 05:28:42 PM
Randy Kvill Randy Kvill is offline
With the gear braces in there, those are the actual wheels, not the extensions.
The Following User Says Thank You to Randy Kvill For This Post:
Old 06-01-2015, 10:10:47 AM
turbo's Avatar
Thanks Randy, I see someone removed the center hub and spokes. I found out from the owner that his dad took them off of "some funny looking cultivator tractor to use as extensions on a John Deere D". I will save them from the scrappers if I can
The Following User Says Thank You to turbo For This Post:
Old 09-10-2017, 01:11:31 AM
FredB2 FredB2 is offline
i believe these tractors had the nickname of widow maker, apparently farmers would tow a wagon load down hill, and the wagon would overrun the sulky. i looked at those tractors, and wonder if anyone ever thought of using channels to make a frame forward and put the sulky in front, making the sulky wheels steer, w/ operator in front of radiator, making it a somewhat normal looking tractor. just a thought. ( probably really have to stretch the word normal)
Help ID extension rim d19klem Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 10-02-2008 09:27:11 PM
Extension Cords Holland501 Welding Shop 8 02-17-2008 02:45:05 PM
LA throttle extension Tom/Idaho Antique Engine Archives 3 08-03-2004 11:16:16 AM
extension rims bill Steam Stationary Engines, Traction Engines, Steam Boats 1 02-20-2004 11:30:58 AM
