eBay Auctions
Go Back   SmokStak > SmokStak® General Discussion > eBay© Auction Discussion
eBay© Auction Discussion All eBay™ discussion; engines, frauds, fancies, weird stuff and more.
Scale Case Traction Engine on ebay
this thread has 15 replies and has been viewed 4584 times
Old 02-10-2015, 06:57:58 PM
Jason Dahm Jason Dahm is offline
Default Re: Scale Case Traction Engine on ebay
I don't have a horse in the race but I'd bet around $8500. Jason
Old 02-11-2015, 08:10:22 PM
OTTO-Sawyer's Avatar
Sold for $7250.00
12 bidders and 47 bids.
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
Old 02-12-2015, 07:43:26 AM
Phil P Phil P is offline
Hi
I got one off Ebay several years ago that looked better than that one in the pictures and it turned out to be in very bad condition.
It took me a year to repair it so I could use it.
Here is a picture of me running it in the front yard.
http://www.youtube.com/watch?v=KXoSlEZLSvc
Phil P
The Following 3 Users Say Thank You to Phil P For This Post:
Old 02-12-2015, 10:53:41 AM
Big Bird Big Bird is offline
thanks for posting the great vid of your traction engine,
what did you have to do to your engine to get it into running condition?
I recently purchased a one third scale case and have to do some refurbishing myself, nothing too serious, governor work and a little tinkering here and there. I will run the engine a few times and do a tear down and repaint This year.
Old 02-12-2015, 10:02:36 PM
Hi
The first thing I did was clean the fire box and smoke box out. Apparently the last time it was run they fired it on coal and the firebox was designed for wood. Whoever was operating it didn’t understand the difference and had put too much coal in and blocked the draft. The unit must have just been put in the barn and left for several years. The smoke box had a birds nest in it.
I Borescope the boiler and found the tubes and boiler shell had some deterioration but nothing serious. I could see the line on the inside where the water had been left but even this was not more than a few thousands deep.
The real problem was the cannon shaft was frozen and I had to remove it to even get the unit on the trailer I picked it up with.
Then I had to replace all feed water lines because they were all rotted out. The feed water pump was so corroded I finally added external check valves and replaced the piston rod.
Then the cleats that were on the bottom of the wheel were it sat came off because the rivets had corroded.
Unfortunately in the video I had forgotten to close the cylinder cocks other than that that was the first run of any duration and the finish of the repair project.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 02-14-2015, 10:13:57 AM
Hey Phil,
thanks for sharing your experiences.
I fired my engine last Sunday, One of the set screws in the governor had loosened off, and allowed the valve in the governor to be sucked downward into the governor body. I had to file a flat spot on the rod that controls the valve, in order to give the set screw more bite. a little trial and error to get the valve set right for proper operation , but once properly set the engine gave me no trouble at all. We were then able to let my girlfriend's 6 year old daughter run the engine around the yard,,,, smiles all around.. she says it's more fun than running our train. Big bird.
Case traction engine 1 inch scale Big Bird Scale Model Engineering 1 01-18-2015 12:15:48 PM
Need Castings For a 1/2 scale 65 Case traction engine, help Luke Struik Scale Model Engineering 14 11-09-2009 08:35:40 PM
1/3 Scale Case traction engine mopar92 eBay© Auction Discussion 2 05-01-2009 12:59:55 AM
1/4 scale Case traction engine. Charles D. Rakes Steam Stationary Engines, Traction Engines, Steam Boats 0 06-24-2003 10:17:36 PM
1/4 scale Case traction engine. Charles D. Rakes Antique Engine Archives 1 05-29-2003 07:47:16 PM
