Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Gas Engine Discussion > Antique Engine Photos
Antique Engine Photos OLD gas engines, hot air engines, Diesels and steam engines. An electronic photo gallery to showcase the best of your old engine collection.
Lauson L-50 Military Engine, Are They Rare?
this thread has 2 replies and has been viewed 1710 times
Old 05-23-2013, 05:02:48 PM
Marc P Marc P is offline
Photo Lauson L-50 Military Engine, Are They Rare?
I just purchased a Lauson L-50 engine. It was told by the owner to be a 1954 (he had badly deteriorated papers with it) and was told it has maybe a couple hours at the most run time on it. He had two of them and the other was even in its crate still when he had it but he sold that one years ago.
I thought about selling it, but before I do, I have some wonders about it, but can't seem to find any info on evilbay or even here to let me know much about it, nor any idea of value.
The base at the rear, four studs in the block and tapered crank let me think it was a generator? Also, why does it have a damper/shutter(?) on the cowl at the rope start end, is it to Preheat faster? Then there is a chamber on the bottom that is ducted up under the carb, it also has an opening on the muffler side, is this a carb preheater/deicer of some sort? I've checked it and the mag is still hot, the last time it did any running was with a soda can fuel tank when this last owner and my brother started it pushing five or so years back, we kind of had been wondering about it since and now that it's mine, I'm real curious.
Thanks in advance if you can help.
Name:	Lauson military 001.jpg
ID:	165896   Click image for larger version
Name:	Lauson military 002.jpg
ID:	165897   Click image for larger version
Name:	Lauson military 003.jpg
ID:	165898   Click image for larger version
Name:	Lauson military 005.jpg
The Following User Says Thank You to Marc P For This Post:
Old 05-23-2013, 10:47:58 PM
bigGURN bigGURN is offline
Images: 1
Default Re: Lauson L-50 Military Engine, Are They Rare?
I'd wonder if it was for a jet engine or other air plan engine warmer/fan. By using the air of the engine that is heated and blown through a fan back into the jet/ air plane engine to warm it up and preheat it?
The Following User Says Thank You to bigGURN For This Post:
Old 05-24-2013, 02:26:31 AM
Ken Karrow Ken Karrow is offline
I have a military standard engine with special ducting and instructions for cold weather operation. I suspect that is what you have. Ken
The Following User Says Thank You to Ken Karrow For This Post:
military generator with lauson engine thetractorfreak Small Air Cooled Gasoline Engines 6 12-05-2012 06:02:53 PM
Lauson 920 (Military) John Newman, Jr. Small Air Cooled Gasoline Engines 6 07-08-2011 10:51:08 AM
WOW! Lauson RSC for a Jari. Rare? mschreiber Small Air Cooled Gasoline Engines 3 05-31-2011 09:13:04 PM
Lauson Military Generator pvtcook Small Air Cooled Gasoline Engines 6 06-18-2009 12:31:39 PM
Military lauson The one banger boy Small Air Cooled Gasoline Engines 3 04-12-2008 08:20:03 PM
