Cincinnati Knee Mill with an NMTB 40 Taper
this thread has 12 replies and has been viewed 5739 times
Old 12-24-2009, 09:27:52 AM
AndyG's Avatar
AndyG AndyG is offline
Default Cincinnati Knee Mill with an NMTB 40 Taper
I bought a Cincinnati knee mill with an NMTB 40 taper. What is the difference between a CAT 40 and an NMTB 40 tool holder?
Old 12-24-2009, 01:14:48 PM
ronm ronm is offline
Default Re: #40 Taper
for some reason, I saved this when I ran across it-you never know...
http://www.tools-n-gizmos.com/specs/Tapers.html
Old 12-24-2009, 01:40:26 PM
Chuck Rhoades's Avatar
Chuck Rhoades Chuck Rhoades is offline
I've used both in my mill a Gorton Mastermill. I had to make a longer drawbar for the cat 40 but they worked equally well.
The Following User Says Thank You to Chuck Rhoades For This Post:
Old 12-26-2009, 11:00:18 AM
AndyG's Avatar
Thanks guys. This is the info that I needed. Same taper and same threads. The length can be easily dealt with.
Old 01-22-2010, 01:59:27 PM
AndyG's Avatar
Default Re: Cincinnati knee mill with an NMTB 40 taper
I finally got a couple of pics of my "new" mill.
ID:	71996   Click image for larger version
Old 01-04-2011, 02:43:55 PM
AndyG's Avatar
I finally got the mill moved into the shop. I was playing around with it and have a couple of questions. There is a small crank wheel on the front of the headstock. What does it do? This machine DOES have power feed on the quill. There are a couple of reservoirs for oiling the ways. What kind of oils should be used?
Old 01-04-2011, 04:38:11 PM
If you put the feed direction lever on the head in neutral, then engage the feed lever you can manually run the spindle up or down. Depending on which direction you turn the wheel. This gives you a fine hand feed, just like a Bridgeport.
Richard W.
The Following User Says Thank You to Richard W. For This Post:
Old 01-04-2011, 06:14:33 PM
Heller D. Davis Heller D. Davis is offline
Andy I use Vactra #4 Way oil from Enco in all my lathes and mill.
The Following User Says Thank You to Heller D. Davis For This Post:
Old 01-16-2011, 11:36:50 PM
AndyG's Avatar
Finally got the mill running today. I'm using a homemade Rotary Phase Converter 230V. I rewired the spindle motor for low voltage and got the 115V control circuits figured out. The table feed work without changing anything which confuses me a little bit. Does the table feed have a clutch between the motor and gearbox. There is a bit of noise and slippage at the higher feeds that I can't figure out. After about 10 minutes of running the spindle motor the entire machine shuts down. Any clues what I need to look into? What is the proper way to run the spindle feed? It appears to work but I can overcome it with the handle on the side. The handle on the front doesn not really seem to do anything
Old 01-17-2011, 06:44:38 AM
Steve NW Ohio Steve NW Ohio is offline
Shuts down after 10 minutes, sounds like a thermal over-load issue. Have you checked the amp draw on the system yet. Check on the primary feed side of your circuits, if you haven't already - the over-loads probably need to be changed to accomodate the lower voltage whioch will rsult in higher amperage draw. Steve C
Old 01-17-2011, 08:38:50 AM
AndyG's Avatar
Is changing the overloads a difficult or expensive thing to do? I would guess that 1/2 the voltage probably means double the amps. So the overload makes sense.
Old 01-17-2011, 09:27:14 AM
K D Redd K D Redd is offline
When you rewired the motor from high to low voltage you caused it's current draw to double. Most industrial machines have heater coils on the contactor that are amp rated. If to much current is pulled through them, they heat up and cause the contactor to "Trip Out" If the contactor is old, finding the correct heater for the higher current you need may be impossible. If you can not find the heaters you will need to replace the contactor. If you have current protection on your Phase Converter, I have them on mine, you could put jumper wire in the place of the heaters. This would by-pass the current protection built into the contactor. Not recommended but if you need to replace the contactor because you can not find the heater for it, the new contactors can be PRICEY.
Kent
The Following User Says Thank You to K D Redd For This Post:
Old 01-25-2011, 02:18:22 AM
prybar prybar is offline
Default Re: Cincinnati Knee Mill with an NMTB 40 Taper
In my Cincinnati I use NMTB 40.
From past experience, Home made or Phase-a-matic rotary, be careful, you should always use a voltage stabalizer. Phas-a-matic makes them I had a factory rotary that worked fine but L3 was putting out way to much voltage, wich can overheat the heaters, not to mention it hard on motors. Solved all my problems. And I run 7 milling machines.
Pre Lunkenheimer Cincinnati Brass Works Oilers Joel Mosley Hit & Miss Gas Engine Discussion 3 07-07-2010 12:07:34 AM
Enco Knee Mill Model No.? Jim Richert Machine Shop and Tool Talk 1 03-20-2010 01:43:52 AM
Greaves Cincinnati Lathe OrgWayne Machine Shop and Tool Talk 1 04-29-2009 12:42:55 PM
Halloing wanted; East Concord NY to Cincinnati OH or KY area Kevin Woodruff Trucks, Trailers and Hauling for Shows 0 07-16-2006 04:57:15 PM
Cincinnati Area Show? Mike Antique Engine Archives 2 05-06-2003 10:03:38 PM
