Welding Shop
Use a welder to test a welder?
this thread has 7 replies and has been viewed 4035 times
Old 02-23-2010, 01:53:46 PM
maddenfarms maddenfarms is offline
Default Use a welder to test a welder?
I hear old timers talk about using one pipeliner to start another and to test a generator of a non running pipeliner by hooking a running one to it. I assume they are doing this by connecting positive lugs to positive and negitive to negitive.Anyone know for sure?
Old 03-11-2010, 06:27:55 PM
Dempster Dempster is offline
Default Re: Use a welder to test a welder?
They aren't testing one they are just using the other welder to excite the armature and turn the other one over to start it.
Old 03-13-2010, 01:35:31 PM
Alan Rudd's Avatar
Alan Rudd Alan Rudd is offline
Back in the early 70s I had an old Lincoln portable that had a chronic starter problem. I also had an old 20s vintage GE dc machine. I would crank the GE all the way up to the stop and turn the Lincoln all the way down then clip a piece of scrap iron between the electrode holders. Pull out the choke and touck the ground clamps together.
This worked without fail many times. Although I don't know if I would try it on some of the modern solid state machines now days.
Alan
Old 04-19-2010, 09:41:18 PM
bobgil bobgil is offline
they call that HOT SHOTING around here, never been there when it was done but I have heard about it being done.
The Following User Says Thank You to bobgil For This Post:
Old 04-19-2010, 10:56:27 PM
Thank You!
Old 07-11-2010, 11:44:43 PM
pipeliner83 pipeliner83 is offline
all you do is hook your ground together with one machine on maxine and 100 and turn the other one thats not runnin on 0 all the way. touch your stinger together and it should fire the other one right off.
The Following User Says Thank You to pipeliner83 For This Post:
Old 05-20-2011, 10:44:20 PM
mcondit mcondit is offline
My question is: can this change the polarity if done wrong?
Old 05-21-2011, 09:47:55 AM
Rick McKay Rick McKay is offline
I've got an old SA200 pipeliner that can be stubborn to start in the winter if it has been sitting for awhile. In the shop I've got a Miller 300, and I've used the Miller 5 or 6 times to start the Lincoln with no problems. I just hooked the ground to ground and pos. to pos. I was a little nervous the first time, but after that it was old hat. The lincoln would turn over almost at running speed! I guess it is like using the welder as a starter/generator. I knew one guy that used 3 12 volt batteries connected in series to start an old lincoln with no starter.
Rick
The Following User Says Thank You to Rick McKay For This Post:
EMF PTO Welder gigerchild Welding Shop 4 12-06-2009 07:19:44 PM
Which welder to keep Holland501 Welding Shop 3 09-10-2008 10:52:23 PM
Old GE welder freebird Welding Shop 0 07-19-2008 05:38:21 PM
Need old mig welder help!!! CAnger Welding Shop 1 11-19-2006 06:45:12 PM
