Onan 1AJ-1R/ ?
this thread has 20 replies and has been viewed 728 times
Old 06-24-2019, 09:48:16 PM
gnucklehead gnucklehead is offline
Talking Onan 1AJ-1R/ ?
Serial# 650602 missing ID tag, 4-pole 120VAC remote-start generator.. I should have left this fester longer on CL but these 1800 AJs are kinda rare
ID:	337828   Click image for larger version
ID:	337829   Click image for larger version
ID:	337830   Click image for larger version
The Following 4 Users Say Thank You to gnucklehead For This Post:
Old 06-24-2019, 10:50:27 PM
Ben Cowan Ben Cowan is offline
Default Re: Onan 1AJ-1R/ ?
Hurricane season is here on the gulf of mexico, send that little guy on south I'll give it a good home. Will fit in with my 4.0cck, 2 6.5's and my recent 7.5JB. I'll be looking for an AJ. Luck, Ben
The Following 2 Users Say Thank You to Ben Cowan For This Post:
Old 06-24-2019, 11:05:21 PM
Jim McIntyre's Avatar
I have no use whatsoever for one of those.
(But if one ever shows up around here, I'm getting it! )
The Following 3 Users Say Thank You to Jim McIntyre For This Post:
Old 06-25-2019, 12:20:37 AM
OnanParts's Avatar
OnanParts OnanParts is offline
1AJ-1R/31G. Loaded up on the truck to leave the factory on November 16th 1960.
https://www.onanparts.com
The Following 2 Users Say Thank You to OnanParts For This Post:
Old 06-25-2019, 01:05:15 AM
Vanman Vanman is online now
I'd bet that would easily run a fridge and a few other small loads. Could be left running all night, consuming very little fuel...
Of course auto start would be even better for all night. That way it only runs when the fridge comes on. Or you turn on a light.
Old 06-25-2019, 10:05:47 AM
I need another generator like a hole in the head .. Just a sucker for cheap cast iron toys, and I don't have room for anything larger
The Following User Says Thank You to gnucklehead For This Post:
Old 06-25-2019, 10:15:34 AM
HBSaunders HBSaunders is online now
You know you want it, come on, admit it!
The Following User Says Thank You to HBSaunders For This Post:
Old 06-25-2019, 11:17:40 AM
Kevin K Kevin K is offline
Exactly! With emphasis on "Cheap", because they really aren't worth anything to the general public, and my chances of getting my money back when trying to sell one are pretty much zero. I would love to have a Kohler 4 cyl water cooled L600 or L654 engine with a 6.5Kw generator head, but absolutely no room.
The Following User Says Thank You to Kevin K For This Post:
Old 06-25-2019, 05:40:07 PM
lokay5's Avatar
lokay5 lokay5 is offline
Thumbs up Re: Onan 1AJ-1R/ ?
Annnnd.....it's gaseous fueled!
I'd've bought that little puppy in a heartbeat!
1973 CK5 Blazer
The Following User Says Thank You to lokay5 For This Post:
Old 06-26-2019, 12:06:52 PM
Yup.. one of my pre-requisites for prying open the wallet. This is my third generator sporting the Carter-N gaseous carb, has a "20" bore (same as the LK).. This one is different, having the curious choke thing.. Could be designed to help with vacuum, and opens proportional to airflow? I've had more than one small generator that sometimes required manually working the throttle back n forth to get it started.
Wiring diagram 610C141 from the older AK manual (925-0500) matches this set perfectly.. It's possible that the old 924-0500 AJ service manual, has the drawing but didn't make it into the newer manuals. There is an A1 wire coming up from the gen-end that is floating free with insulated ring lug on the end, but pretty sure that is isn't used on this set (no choke, no charging relay). If anyone has a better copy, I'd appreciate it. I might draw up a schematic, and would like to label it properly.
Last edited by gnucklehead; 06-26-2019 at 04:34:16 PM. Reason: Removed lower quality drawing
Old 06-26-2019, 04:15:16 PM
This is what I have for 610-0141. Just a question, if the tag was missing, how did you know it was an 1,800RPM version of the AJ? Did you hear it run?
Old 06-26-2019, 04:45:30 PM
Studying parts manuals - noting the flicker points on the side.. Only the newer vacuflow-style 2.7/3.0 AJs have ignition points at that location, in a thinner box.
I remember one being discussed in a thread here, was a high-probability guess. If not for that, I would have waited him out and maybe got it for less $$..
I stopped him from trying to start it up because of all the control/output/AC wires being tangled up with bare ends, might short something out.
Old 06-26-2019, 05:14:27 PM
There will also be a set of pole shoe bolts on the bottom of the generator that you could look for (and under the control box).
That's the nice thing about Kohlers. Four pole machines have their poles set a 45* from straight up/down/sides so they can be spotted instantly.
Old 06-26-2019, 06:09:15 PM
Zeromedic Zeromedic is offline
Try this manual.
http://www.skilledcrafting.com/onanf...n%20manual.pdf
Steve
The Following User Says Thank You to Zeromedic For This Post:
Old 07-12-2019, 09:59:02 AM
A few evenings with some cleaner, blue-paper shop towels and nylon brushes.. There's some nice green under the grime. Top tins have some scratches, but I haven't found anything wrong with it..
It's like a toy, yes just enough to be useful.. I forgot to snap a photo of the blower housing top - silkscreen note with something like - Emergency Service - Test Weekly......."
ID:	338930   Click image for larger version
The Following 5 Users Say Thank You to gnucklehead For This Post:
Old 07-12-2019, 10:54:14 AM
nothingbutdarts nothingbutdarts is online now
It's purdy!!! I have a few you could clean up for me if you would like.
The Following User Says Thank You to nothingbutdarts For This Post:
Old 07-12-2019, 11:09:46 AM
Dale Russell Dale Russell is online now
Looks like it's fresh out of the Factory!
The Following User Says Thank You to Dale Russell For This Post:
Old 07-12-2019, 01:56:20 PM
That's a beauty! No repaint can ever be original!
Old 07-12-2019, 02:44:21 PM
07wingnut 07wingnut is online now
Nice job, it looks like new.
The Following User Says Thank You to 07wingnut For This Post:
Old 07-13-2019, 09:02:33 AM
Wheel1943 Wheel1943 is offline
Jack---That is a beauty--bet you can almost pick it up, and hold it, it sure is cute enough. Wheel
The Following User Says Thank You to Wheel1943 For This Post:
