Vertical Famous Podlesak and JY1 Podlesak
this thread has 4 replies and has been viewed 455 times
Old 10-13-2018, 12:33:53 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
Default Vertical Famous Podlesak and JY1 Podlesak
I have the brakcet for a 3 hp vertical but the wrong mag
I need to know what this mag JY1 fits and which one I need. My Wendals note books are hiding. Would trade mags with some one.
I also have bracket that is broken. If some one has a mag with a broken bracket on it.
ID:	320729   Click image for larger version
ID:	320730   Click image for larger version
ID:	320731   Click image for larger version
Old 10-13-2018, 05:16:04 PM
Scott Kocher's Avatar
Scott Kocher Scott Kocher is offline
Default Re: Vertical Famous Podlesak and JY1 Podlesak
Matthew if I'm not mistaking the jy podlesak will fit the 6 hp famous
I think you might need a jz podlesak for the vertical bracket you have
because I bought a jz mag for my 4 hp famous & was told that mag came off of a vertical
some one can correct me if I'm wrong
Scott
The Following User Says Thank You to Scott Kocher For This Post:
Old 10-13-2018, 05:58:54 PM
I am digging for my Wendals. I also think the tripper part on mag is different. Do you have that Scott ?
Old 10-13-2018, 06:19:40 PM
Famous Fitter Famous Fitter is offline
Hi all
JY is for 6hp horizontal up
JZ was on 2.5hp and 4hp horizontals and 2-3HP vertical with different trip fingers to suit.
It would appear that up to around 1910? The podelsac mags went from Brass body to aluminium but otherwise fit in the same spot. Webster made a die cast version too - not as good in lasting the tests of time.
Hope this helps - Justin
The Following User Says Thank You to Famous Fitter For This Post:
Old 10-13-2018, 06:28:10 PM
no matt I don't I had to give that back
IHC Famous Vertical 2hp Pascal22 Antique Gas Engine Discussion 21 07-10-2018 01:31:53 PM
2 HP Vertical Famous ?'s Mike Smith Antique Gas Engine Discussion 5 05-13-2013 09:26:10 PM
Podlesak Magneto photos wanted please OzEngines Antique Gas Engine Discussion 0 02-03-2008 06:06:32 AM
2 hp vertical Famous? Johnny T Antique Gas Engine Discussion 20 01-10-2008 10:20:40 PM
2 hp Vertical Famous Chad Antique Gas Engine Discussion 5 07-05-2005 06:57:43 PM
