Restoration Tip
this thread has 3 replies and has been viewed 1075 times
Old 06-11-2016, 01:28:12 PM
Gene Fisher's Avatar
Gene Fisher Gene Fisher is offline
Images: 6
Default Restoration Tip
When trying to remove slotted screws that are stuck and the slots are in bad condition i use a 6 L N Vise Grip pliers to get the screw started. Then you can go back to the screw driver. It is a small needle nose type vise grip and will without a doubt help remove bad screws that need to be replaced.
The Following 8 Users Say Thank You to Gene Fisher For This Post:
Old 06-11-2016, 04:18:24 PM
ThreeHitsandaMiss ThreeHitsandaMiss is offline
Default Re: Restoration tip.
Done that a few times always worked out well for me,good tip.
Old 06-12-2016, 07:55:10 AM
Email NOT Working
Yes vice grips are one of the greatest things to ever come out of Nebraska. But I never found the needle-nose style to be strong enough for the really tough jobs. Mine wanted to Spring a little bit out of shape. It's sad that company went to China now. But mr. Peterson was a genius to invent them.
The Following 2 Users Say Thank You to Kevin O. Pulver For This Post:
Old 06-12-2016, 10:08:18 AM
Edgar Edgar is offline
i have used an impact screw driver you twist it one direction and hit the end with a hammer you dont see too many listed in new tool sections anymore but craftsman years ago used to have them
The Following 2 Users Say Thank You to Edgar For This Post:
6HP Associated restoration Luke Antique Gas Engine Discussion 4 01-31-2012 05:57:15 AM
A Reo Restoration Mac Leod Small Air Cooled Gasoline Engines 11 06-11-2009 12:12:00 PM
I.D. Tag restoration Sean B. Small Air Cooled Gasoline Engines 2 02-20-2006 04:15:00 PM
Restoration Ed Welsh Antique Engine Archives 0 02-26-2003 03:59:02 PM
