Polisher Restoration
this thread has 61 replies and has been viewed 3377 times
Old 04-16-2017, 10:32:07 PM
Default Polisher Restoration
Drug this old polisher out of my to-do pile yesterday. Stripped the base/pedestal last night, and the motor today, with the exception of the data tag.
Any suggestions on cleaning up the data tag? Pretty sure its an aluminum tag and wire wheel would just obliterate it. Would be nice to know mfr and voltage. The bottom tag is a brass inventory control type tag with numbers stamped in it, I will just polish it for some bling.
Peeked under the base yesterday, no capacitors under there. From the plug there are 3 wires, 1 goes directly to the motor, other 2 go to the switch. The plug that is on it looks like a 220v dryer/stove type plug, did they make these to run on 220v? Would the lack of capacitors be a clue that its 220v? How would I go about positively identifying what voltage this thing runs on?
I do not think its a 3 phase motor, but could be wrong.
ID:	280192   Click image for larger version
Old 04-17-2017, 12:00:08 AM
Vanman Vanman is offline
Default Re: Polisher Restoration
It could be split phase or repulsion start. Agreed that that looks like a 240 volt, 30 amp, single phase plug.
For nameplates I like to use an oil soaked rag. No abrasives! Only makes 'em worse.
Keith
Old 04-17-2017, 12:30:00 AM
Split phase = 220v single phase? If repulsion start I sure hope all those parts work so I don't have to crack motor open........ Those little things on the top of motor are little tiny grease cups, anyone want to take a guess on mfr and age? My plan is to set this one up with muslin wheels for polishing.
Old 04-17-2017, 01:52:50 AM
Yes, split phase motors are single phase. I have also seen old capacitor start motors that have flat capacitors, that look like sardine cans, mounted in the base.
Repulsion start motors do benefit from an occasional cleaning / service. If that's what it is, there would most likely be some removable covers for access / inspection. They are my favorite type of single phase motor though.
As a completely wild guess, I'm going to say 1940's or perhaps '50's. Looks old enough to be good.
Keith
Old 04-17-2017, 02:31:54 PM
Originally Posted by akuna View Post
You come up with the best junk.
Ever get the backhoe working in Texas? Or you a permanent Nevada resident now?
I'm back in Texas at the moment, the big push on finishing up projects is because I'm hauling a bunch of tools back to Nevada soon, I'm getting tired of the drive.
The tractor is a bit of a sore subject right now, friend did nothing to finish it up and pushed it into the weeds. She is the one doing all the dirt work these days, so I just don't get why she did not finish it. I need to drag it back up on the pad and try to finish it up.
Old 04-17-2017, 09:44:24 PM
s100 s100 is offline
It's my guess that your machine is a Cincinnati. It's had to tell without any reference but I would guess it to be 1HP. Cincinnatis are very good machines and well worth the effort to get going again. That said there's a lot of similarity between brands so no telling what your tag might reveal. But Cincinnati was a manufacturer so if your tag says otherwise it might merely be rebadged. As to age, who knows? Could be pretty much anything from the 40's on. The aluminum tag implies a later machine, maybe late 50's or newer.
It's even harder to guess what (or IF) some long ago screwball was thinking when he/she connected the machine to a line. It was me, I'd pull the end bells off the motor and that will tell the story as to whether single or three phase. Still some doubt about voltage, though, although that's easier resolved. And while you're in there, you can clean out ages of dust and crud, and repack or replace the bearings, and, if warranted, replace the leads to the motor or cover them with some shrink tubing. I've seen your other projects posted here and you aren't one to back off from doing things right. Don't crap out on us now!
If I was forced to make a guess at this distance I'd say it's three phase, and, being small, more likely 240 than 480V. But that guess is worth exactly what you paid for it. One thing you can do is to measure resistance between the three wires and to ground. If the thing is single phase and even remotely properly wired, the two wires to the switch should be the two lines and the third, direct wire should go to ground and should be electrically isolated from the other two. If none of the leads have resistance to ground and the same resistance between any two leads, it's three phase and very improperly wired. A hot lead should NEVER be directly connected to a load, all three MUST be switched.
Whatever you find, be it single or three phase, try running the motor on the lower voltage and if it starts and runs properly and makes good power then you're golden. If it's wimpy the odds are it's wired for high voltage.
If it is three phase and it is 480V, you have three options. One, run it like it is and be happy. Two, connect the motor to the line through a small step up transformer. Three, dig into the motor to find the winding connections and reconnect them for lower voltage. If you don't know how to do this it's best done by a motor shop, and shouldn't be too expensive.
Good luck!
The Following User Says Thank You to s100 For This Post:
Old 04-19-2017, 12:38:08 AM
Did a little cleaning on the data tag this evening, mfr is a mystery still, think I can see a C, but its really hard to tell. Did figure out the most important things, rpm is 3450, and bottom line of tag I can make out 220 60 3, so its a 3 phaser. I guess its not the end of the world, this would probably be an ideal place to use one of those add-a-phase things, anyone remember the real brand name of those?
S100
I really was hoping to avoid pulling the end bells, bearings spin nice and free by hand, if it sounds bad running I guess I'll have to go back in. With a sealed housing like that how much junk gets in? There are some letters in the pedestal casting CET.Co iirc, I'll get a pic.
Edit: Seems add-a-phase is Ronk, I seem to remember someone posting a link to just a little capacitor contraption in another thread, anyone remember that item? IIRC it was probably small enough I could stuff it into the base of this thing.
---------- Post added at 09:38:08 PM ---------- Previous post was at 09:12:22 PM ----------
Ok, I found the link I was thinking about, not sure if its still a good link though www.phazpak.com
Of course that got me thinking, my rotary phase converter, iirc, is just a 3 phase motor with a bank of capacitors. Well I've got capacitors, oodles of them, so maybe if I just used the right number of them I could run this thing on 220v 1ph?
Essentially turn the buffer into a rotary phase converter, only not running power further down the line? Will that work?
Old 04-19-2017, 02:09:25 AM
Yes, exactly that. As long as you are using run caps, not start caps.
If you can find the full load current, or at least the hp, we should be able to get a pretty good idea of how many ufs to use.
Keith
---------- Post added at 11:09:25 PM ---------- Previous post was at 11:05:21 PM ----------
Oh, I think that those things were called Phase - O - Matic phase converters. But converter was a misnomer. They start a three phase motor with a cap, but then the motor just runs on single phase. With only 2/3 capacity.
Old 04-19-2017, 09:17:52 AM
I have a little Phase-A-Matic on a Do-All bandsaw. Works great! Forget it's even there.
The Following User Says Thank You to beezerbill For This Post:
Old 04-19-2017, 05:56:19 PM
pauljac pauljac is offline
I have a Cincinnati bench grinder and the brass ID tag measures 3.25" X 1.625" with the mounting holes on 3.125" centers.
The Following User Says Thank You to pauljac For This Post:
Restoration Tip Gene Fisher Antique Gas Engine Discussion 3 06-12-2016 10:08:18 AM
Inexpensive Crankshaft Polisher Jim Parrott Machine Shop and Tool Talk 0 01-07-2016 11:57:13 AM
Restoration Ed Welsh Antique Engine Archives 0 02-26-2003 03:59:02 PM
