Oil Field Engines
Water in Fuel
this thread has 10 replies and has been viewed 601 times
Old 03-11-2019, 08:11:16 AM
Joel Sanderson Joel Sanderson is offline
Default Re: Water in Fuel
Bill, Yes, I tried ethanol-free gas. It doesn't run as well--harder to get to run evenly (ignite evenly) under varying load than with ethanol. I really should type out all the mixtures I tried and put them here for everyone to see and comment on. I'll try to remember to bring my notes home from the shop today. It'd make for a very long post though.
Andrew, I think it's really interesting that your 1 1/2 hp M ran on 50/50 without ignition. Did you try it on straight gas or straight kerosene? I'm gonna guess that it wouldn't run without ignition unless the fuel was mixed.
The Reid's governor's strong enough I could put a link to a water valve fairly easily so it opens only under heavier load--without having to make a new carburetor. I think that's like you suggested, EMU. (I was thinking new carb up until now.) That'd be fairly simple to do other than needing my other engine belted and plumbed so I can work on the Reid while it's down. Drat.
The Following User Says Thank You to Joel Sanderson For This Post:
Onan 12.5jc water in fuel rodymartin Onan Generators 8 08-03-2013 06:22:52 AM
lister fuel and water problems lilfatchef Vintage Diesel and Oil Engines 7 08-23-2011 12:33:24 PM
25 40x Rumely fuel & water tanks Rod Gaffrey Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 08-20-2011 10:10:34 AM
Installing CAT fuel water separtor Isaac-1 Generators & Electric Motors General Discussion 2 06-23-2010 05:23:56 PM
