Confused by taper thread vs model engineer thread
this thread has 4 replies and has been viewed 1543 times
Old 01-29-2016, 11:22:49 AM
AppalachianSunrise AppalachianSunrise is offline
Default Confused by taper thread vs model engineer thread
Hello everyone,
I had a custom coal fired boiler built in the UK and the builder told me I need a model engineer thread? The size of copper pipe I'm using to connect everything together is 5/32 inch. My question is, what kind of american stranded tap and die would work? "1/4 x 40 UST" or "1/4 x 40 MTP" I'll be connecting everything up to run two PM Research steam engines, I would greatly appreciate anyone's help in getting my steam plant connected up.
Regards,
Heath
Old 01-29-2016, 12:00:15 PM
Big Bird Big Bird is offline
Default Re: Confused by taper thread vs model engineer thread
check out p_m research. on their site they have an article about n.p.t compared to me. threads. Some will interchange , some won't. Model engineer is a british straight thread.
Other threads are
Mpt. model taper pipe
Me. Model engineers also known as British straight Thread
UST. Universal straight taper. its Made by pm research.
Npt. National pipe taper
Metp. model engineer tapered pipe. which is the British equivalent of MTP.
Hope this helps... I probably just added to the confusion...
But I think you would want to use "ust" Universal straight taper. I think it will interchange with "me" British straight thread.
The Following 2 Users Say Thank You to Big Bird For This Post:
Old 01-29-2016, 02:22:11 PM
Yeah sorry you did. All I wanted to know would the model engineer thread would it interchange with "1/4 x 40 UST" or "1/4 x 40 MTP
Old 01-29-2016, 02:36:50 PM
1/4- 40 ust will work for 1/4- 40 me and will screw up nice and tight.. If just using straight thread. You will want to use some Teflon tape or a sealer of some sort on the threads..
The Following User Says Thank You to Big Bird For This Post:
Old 01-29-2016, 11:05:48 PM
Ray Freeman Ray Freeman is offline
I think the ME threads are 55 deg against 60 for UN. You can buy ME taps cheap enough. Less than 10 bucks on UK ebay. I've just bought a 3/16 and 1/4 for 6.95 each.
Fordson Model F 1925 Restoration Thread audiobull Antique Farm Tractors 37 09-04-2015 02:22:35 AM
RH or LH thread on crank of Model 10CW-3R/1C? GerryL Onan Generators 4 12-04-2014 09:43:15 PM
Thread size on Model 92 Crank pecker1951 Maytag Engines and Collectibles 2 08-02-2013 07:56:18 PM
Difference between Thread Restorer....Rethreader...and Thread Chaser??? packrat56 Hit & Miss Gas Engine Discussion 12 07-31-2007 12:59:11 PM
Briggs Model 14 Muffler Thread Repair Jim Metzger Small Air Cooled Gasoline Engines 15 10-12-2006 04:05:56 PM
