WK40 Mccormick - how many are out there?
this thread has 145 replies and has been viewed 28459 times
Old 04-24-2018, 08:52:50 AM
Russ Hamm's Avatar
Images: 1
Default Re: WK40 Mccormick - how many are out there?
I can look but it might be tonight, maybe somebody will answer before then. I go by the red diamond truck engine torque specs.
Old 01-03-2019, 09:07:43 PM
MrBishop1 MrBishop1 is offline
Images: 6
Anyone know a source for a head gasket?
The Following User Says Thank You to MrBishop1 For This Post:
  #143
Old 01-15-2019, 11:31:14 AM
Images: 6
Olson Gaskets just sent me a whole gasket set. Wasn't advertised on their site but they had it.
The Following 3 Users Say Thank You to MrBishop1 For This Post:
  #144
Old 01-15-2019, 01:05:55 PM
Russ Hamm's Avatar
Images: 1
Here is one we picked up some years ago, put wheels on it and stuck it in the shed. Have since found a good gas tank and manifold, had to load it like this after the sale. Has a red diamond engine in it with distributor but has the mag mount.
I just remembered I needed to ask about starters, I recall a Minneapolis Moline and a John Deere starter will fit, any part numbers?
The Following 8 Users Say Thank You to Russ Hamm For This Post:
  #145
Old 01-15-2019, 10:35:25 PM
Russ...sometime I would like a closeup picture of how the throttle linkage got revamped as the stock tractor linkage will not work with a distributor installed.
Starters off of gas powered Oliver 77 and 88 tractors will work...also heard that the early McCormick W-9's that used the 3 bolt mounting flange will also work.
I see that yours has a Red Diamond oil filter base on it which is a nice upgrade as opposed to using the one off of the original FBB298 motor. I'm still on the search for one of these. Not all Red Diamond truck motors used the oil filter base with the filter can in the upright position. Red Diamond Power Units used the correct base but those are even harder to locate.
My W40 project is hung up on the radiator end. The radiator out of cracked block tractor leaked like a lawn sprinkler. The one out of the burnt tractor didn't leak but from what I could see of the cores almost all were plugged with rust. Still have one more to try but it's on a tractor carcass yet.
The Following User Says Thank You to Mark Schneider For This Post:
  #146
Old 01-16-2019, 11:29:33 AM
Russ Hamm's Avatar
Images: 1
Ill check that out Mark, its not too hard to get to but im chained to work until 6 every week day and its so darn dark lately. There are a few power units around here.
Thanks for the starter info, I have it all written down somewhere from years ago but …………….
The Following 2 Users Say Thank You to Russ Hamm For This Post:
McCormick LA/LB Old Kansas Carburetors, Mixers, Fuel Pumps and fuel delivery 1 04-09-2017 12:49:54 PM
W12 McCormick Chester Antique Farm Tractors 2 03-18-2014 09:41:46 AM
parts wanted for wk40 jamie davey Antique Farm Tractors 2 07-19-2006 10:55:41 PM
1-1/2 hp McCormick M Bill Antique Engine Archives 2 07-30-2004 07:47:03 AM
McCormick M Tanner Remillard Antique Engine Archives 4 03-11-2002 01:59:39 AM
