Doing a pair of Rumely cylinders
this thread has 7 replies and has been viewed 1071 times
Old 01-11-2019, 09:41:25 PM
Reed Engine's Avatar
Default Doing a pair of Rumely cylinders
Boring and sleeving the cylinders from a Rumley. Not sure of the model but the bore is 8Ē.
ID:	326171   Click image for larger version
The Following 8 Users Say Thank You to Reed Engine For This Post:
Old 01-11-2019, 10:51:46 PM
Bubbles Bubbles is offline
Default Re: Doing a pair of Rumley cylinders
20-40 Model G.
The Following User Says Thank You to Bubbles For This Post:
Old 01-12-2019, 09:16:08 PM
DTurner DTurner is offline
Whatís the clearance for that ,between the piston and cylinder?
The Following User Says Thank You to DTurner For This Post:
Old 01-13-2019, 09:41:31 PM
Mark Schneider Mark Schneider is online now
That's a good question...or slightly rephrased would be "What was the original piston to cylinder bore clearance that Advance Rumely gave their 2 cylinder Oilpull engines when new?"
I imagine that this clearance would be dictated by the operating temperature of the cooling system and the related components under load. Most of the "rule of thumb" clearance numbers used now are calculated assuming water as coolant. With water being used maximum cooling system temps are limited to the boiling point of water...212 degrees F. However the tractor in question uses light oil as a cooling medium without the benefit of a conventional tubular radiator so this temperature has to be hotter...and maybe much hotter?
Has anyone established just how hot the cooling oil gets in an Oilpull engine under load?
The Following User Says Thank You to Mark Schneider For This Post:
Old 01-13-2019, 10:40:29 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
They run hot enough that any water trapped in the cooling oil will turn to steam and it will vent off like a guyser at Yellowstone! Those big pistons will heat up and expand a good bit, likely will need .008- .010 clearance?
The Following 2 Users Say Thank You to FWurth For This Post:
Old 01-13-2019, 11:19:23 PM
lukeste lukeste is offline
Images: 1
Just did mine... did 11 thousandths
The Following 3 Users Say Thank You to lukeste For This Post:
Old 01-18-2019, 09:45:34 AM
Iím doing them 8.000. The clearance is on the pistons.
The Following User Says Thank You to Reed Engine For This Post:
Old Today, 07:39:00 PM
Default Re: Doing a pair of Rumely cylinders
A few more pictures.
ID:	326781   Click image for larger version
ID:	326782   Click image for larger version
2nd pair fetched W.P.Klein Oil Field Engines & Related Equipment 2 07-04-2016 09:32:35 PM
Pair of 857 Wheelhorses wheelhorseman Garden Tractors / Mowers / Scooters 4 01-07-2014 09:17:08 AM
pair of hurcules zxb dirtycurt Multi-Cylinder Stationary Engines and Power Units 2 07-02-2012 11:51:21 PM
A pair of 3HP 2A's Jim Sherman Antique Engine Photos 2 09-12-2011 08:45:27 AM
