Longfender AC 20-35
this thread has 38 replies and has been viewed 5587 times
Old 05-08-2012, 11:54:17 AM
Phil Johnson's Avatar
Default Re: Longfender AC 20-35
Thanks, Paul. Good to review that thread again. I'll give you a call soon.
Old 05-08-2012, 03:52:31 PM
I removed some "patina" from the engine today and got to the casting numbers and engine number. The engine has the brass ID tag #32344 and the casting numbers on the block are AM1153 - 15. I believe this is the original 1925 engine fitted with later heads, manifolds etc and front cover. I have an early '27 20-35 and it's casting number is AM1153 - 17. The engine number on it, #33824, is stamped directly on the block as are all my later 20-35's
  #23
Old 10-03-2012, 04:01:49 PM
An addition to this project which is in the "gathering parts" stage.
I found another "parts tractor" locally which has a lot of the pieces that were replaced or missing on the first one. this one has the correct front axle and engine castings, complete radiator and some other small bits and pieces. Still no front wheels yet. I think these fenders are better also.
ID:	146390   Click image for larger version
ID:	146391   Click image for larger version
ID:	146392   Click image for larger version
The Following 5 Users Say Thank You to Phil Johnson For This Post:
  #24
Old 10-03-2012, 04:06:45 PM
A few more pics.
I noticed the rear wheels on this one have plainer hubs than the other one. Engine number is earlier;-32102. Serial tag that came with it is later #7421. This tag is loose and may be from another tractor that was in the same area some years ago.
ID:	146395   Click image for larger version
ID:	146396   Click image for larger version
ID:	146397   Click image for larger version
The Following 3 Users Say Thank You to Phil Johnson For This Post:
  #25
Old 10-03-2012, 04:26:58 PM
Paul Roidt Paul Roidt is offline
Images: 115
Looks good Phil, looks like the casting number on the engine is 14, but with cast valve covers. Did you get to serial number tag?
Paul
The Following User Says Thank You to Paul Roidt For This Post:
  #26
Old 10-03-2012, 04:56:05 PM
Brothers Clemens's Avatar
Thumbs up Re: Longfender AC 20-35
Looking great Phil.
Wonderful donor find for you AC.
Now you can make something very nice
Congrats
Old 10-03-2012, 08:25:48 PM
Paul; there was a serial number tag with the tractor but not mounted -- #7421. I don't know if it is from this tractor or not. As I mentioned in my post, it may be from another tractor that was there a number of years ago.
The rear wheels are different then my '25. Are they earlier or later?
Old 10-03-2012, 09:40:15 PM
chas2545 chas2545 is offline
Phil here is a picture of my 1926 the wheels look the same as your parts tractor.
Old 10-04-2012, 08:18:43 AM
Images: 115
Phil,
You keep making it harder for me not to plan a vacation to your area in the future. LOL
The the wheels on your second tractor I would say are newer. The lugs on the center hub, like on your older wheels, are machined on mine and where to accept extensions of some sort. I have never seen a pair but they are in the parts book.
Both tractors are 1925 or 26 by the fenders with the stiffening ribs in them.
Most 25 & 26 tractors I've looked at have tin valve covers, with the cast covers on older tractors.
Paul
The Following 2 Users Say Thank You to Paul Roidt For This Post:
  #30
Old 10-04-2012, 11:44:06 AM
Chas2545; I don't see a picture????
The serial plate that came with it is a '26 so that is probably the correct one for this tractor.
1924 Allis Chalmers 20-35 Longfender Paul Roidt Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 73 01-15-2013 03:24:39 PM
Allis 20-35 LongFender chas2545 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 16 06-21-2011 12:25:52 PM
Allis Chalmers 20-35 longfender Brothers Clemens Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 12-29-2008 03:38:01 PM
