Help!!--Stearns Engine Designations D-DR-DU Etc.
this thread has 27 replies and has been viewed 4020 times
Old 10-17-2012, 04:46:43 PM
Default Help!!--Stearns Engine Designations D-DR-DU Etc.
Several Stearns engine "series" had the designations A-AR-AU, D-DR-DU etc...(all within each "series" same b/s)...
I've got a Stearns ad which says the "A" version is open flywheel type, no Bell/flywheel housing; that the AU version was with the Bell/flywheel housing for tractors of unit construction. I assume this holds true with the D etc series.
Does anyone here know how the "AR/DR" version differs, or what the "R" designates??
Any comments appreciated! Many thxx!! Bud
Old 10-17-2012, 06:51:42 PM
Joe P Joe P is offline
Default Re: Help!!--Stearns Engine Designations D-DR-DU Etc.
I would like to see a pic of these early style of stearns engines. My Stearns/Gile tractor (missing the engine) shows the manifold on the opposite side as a huber in the tractor book but with the same engine bore and stroke.
The Following 3 Users Say Thank You to Joe P For This Post:
Old 10-17-2012, 07:38:14 PM
xplor xplor is offline
1926 that the first new model under the new management would be announced, the Model D series 6-85. Actually the engine from the larger sleeve- valve six, the model S-6-95, which was upgraded in January of 1925, would be updated and retained for the new model, at least for the time being. Engine improvements were on the way, but there had not been enough time to complete them.
http://www.nevadarockhounds.com/AWA/...y/History.html
The Following 2 Users Say Thank You to xplor For This Post:
Old 10-17-2012, 11:15:52 PM
Xplor;
That's an excellent link on Stearns. Same Stearns as in the 40-62 Huber? I spent over an hour and learned a bunch on sleeve valve engines which always interest me. We (son) have a Wyllis Knight Sleeve valve car and in my shed. Thanks
Old 10-17-2012, 11:22:07 PM
JOE: This ad has no date (it's in "Tractor Quondam", a little booklet of reference book copies of tractor models and assorted ads, by AP Lang in 1971).
Illus is of vertical 4cyl ohv, plugs on passenger side in cathedral shaped openings in side of head, plugs look like 45 degree angle, with petcocks just below in block.
Fan is mounted on stalk,driven by flat belt pulley off front of accessory drive on pass side, driving water pump and mag, with what must be round oil press gauge between and just below wp and mag.
Rad hose connec to radiator comes out of center of head in front of engine.
Manifold, carb would be on drivers side.
May have some other Stearns ads with dates; will check
EXPLOR:---nice history, but no cigar---my Stearns was Justus Smith Stearns of Ludington, MI--Stearns Motor M'f'g Co, later Stearns Motor co, which grew out of/descended from Gile Tractor & Engine Co and/or other Gile companies there in Ludington. My Stearns made his money in timber/lumber, then added everything else he stumbled across. He gave up engines in 1930 or so.
OILPULLED: None of the Stearns in tractors are listed as Stearns-Knights, so I doubt any connection, unless in generations prior to engine building.
The Following User Says Thank You to Bud Tierney For This Post:
Old 10-18-2012, 11:24:39 AM
You are looking for Gile engines of Ford tractor fame made in Ludington, Michigan . Justus Smith Stearns was the money man.
---------- Post added at 11:24 AM ---------- Previous post was at 11:18 AM ----------
http://www.oldmarineengine.com/discu...s/1/91492.html
Old 10-18-2012, 12:06:37 PM
No, I am looking for a pic of the 4 cylinder engine that Gile developed in 1918 and was used in the Gile model Q tractor in 1919 and in 1920 was renamed Stearns tractor and used in the same tractor but now under their new name and later went on to be used in a lot of Hubers after more refinement. The engine is listed in Chilton 1918 book in the tractor engine section as a model P with a 4.75 x 6.5 bore and stroke. By 1921 Stearns calls this motor a model AU.
Old 10-18-2012, 12:46:25 PM
Joe: Haven't found any earlier ads on the A/AU or any Stearns; when Lang made thisbooklet up he blocked out all the original magazines names/dates, but an Eisemann mag ad in the same book shows "(c)1920"...
Email or PM me an email adds and I'll try emailing a pic; the ad has mostly engine specs you'll probably find interesting.
I've been having trouble with my set sending MB pix instead of GB pix, but if I can't make it work will mail a Xerox copy.
Old 10-18-2012, 02:08:33 PM
Are you looking for one of the three Stearns super four engines built in 1926 and tested in Nebraska?
The D model was in the middle, called the 20-40 before the test and 32-45 after. Du would mean it had a bell housing for a tractor.
Old 10-18-2012, 08:21:14 PM
To add information I own a 1924 Bear Crawler made in Boston, Mass and it is powered by a Model AU Stearns 4 Cyl. I believe it is rated as 55 HP which is listed on the Bear tag on the gas tank. ED B
The Following User Says Thank You to Ed Bezanson For This Post:
Stearns 850 Mike Schweikert Generators & Electric Motors General Discussion 1 09-02-2012 11:52:24 AM
Unscrambling Lauson Engine Type Designations Craig DeShong Small Air Cooled Gasoline Engines 22 08-26-2011 09:54:23 PM
Old Buda Engine designations (IU,ITU,etc) Bud Tierney Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 14 05-23-2008 11:13:33 PM
Lincoln Welder Designations?? Bud Tierney Welding Shop 0 12-09-2007 03:42:27 PM
Kohler Generator Designations ListerDiesel Kohler Generators 0 10-02-2005 12:41:46 PM
