Twin City 20-35 "Canadian"
this thread has 244 replies and has been viewed 25852 times
Old 12-22-2018, 02:15:07 PM
Default Re: Twin City 20-35 "Canadian"
Duey...The arbor speed on the Ames is quite slow and I made multiple passes as the drive belt set up will slip if the cut is too aggressive. About 50 thou a pass worked well...when I finished the shaft was barely warm.
The Following 2 Users Say Thank You to Mark Schneider For This Post:
Old 12-23-2018, 01:05:52 AM
Duey C Duey C is offline
Very cool. I was stunned at the 50 thou per pass cuts but I get it better now. : - )
Have you fitted it together?
Old 12-27-2018, 11:06:35 PM
Working on setting up the primary bevel gears.
1. For those who haven't been exposed this is the classic Hyatt bearing set up. This was the cutting edge of bearing technology in the teens and twenties. The large roller takes up the side load while the radial ball bearing handles the end thrust. This was a big improvement over babbitt and straight roller bearings. When the Timken tapered roller bearing was introduced the bearing quills could be preloaded for zero end play and this obsoleted the Hyatt design.
2. As is my tendency I replaced the felt wiper on the input shaft with a modern lip seal.
3. The Hyatt bearing system uses the tendency of gearsets to push each other apart to take the slack out of the bearing quill... but in one direction only. If the shaft is pushed the opposite direction it simply comes out of the quill. I made this collar and set screw to keep the assembly together on the numerous trips on and off to set up the gear tooth depth.
4. There is another Hyatt bearing assembly in this quill for the belt pulley shaft. The end thrust from the driven bevel gear is absorbed here. The gearset backlash is adjusted by paper gaskets between the quill and the case. The backlash can only be approximated at this time as the input shaft has to be supported by the flywheel pilot bearing before the final check is made.
ID:	325251   Click image for larger version
ID:	325252   Click image for larger version
ID:	325253   Click image for larger version
The Following 13 Users Say Thank You to Mark Schneider For This Post:
  #244
Old 12-30-2018, 09:14:38 AM
Eric Best's Avatar
Eric Best Eric Best is offline
All of my Hyatt bearings on my 20-35 were pretty tired. I made sleeves and spacers and except for the differential and outer ends of the rear axle, all hyatt bearings have been replaced with ball bearings. Smooth as glass now.
The Following 3 Users Say Thank You to Eric Best For This Post:
  #245
Old 12-30-2018, 05:23:22 PM
Eric...Did you retain the ball thrust bearings on the input and belt pulley shafts or are you letting the new ball bearings absorb the end thrust by themselves?
Rumely 36 HP " Canadian model " restoration nearly complete. George Hoffman Steam Stationary Engines, Traction Engines, Steam Boats 62 08-21-2017 10:47:26 PM
"Twin City 25-45" Model Build Completed Culy Scale Model Engineering 37 12-30-2012 04:11:39 PM
MONARCH by "Canadian Engines", Dunnville, Ontario. Denis Rouleau Antique Gas Engine Discussion 22 09-06-2010 07:29:15 PM
Canadian ..... "Page" Engine Owen Bosma Antique Gas Engine Discussion 8 08-30-2010 11:13:49 PM
Head lines in "The Derrick" Oil City's local newspaper Bruce Golden Antique Gas Engine Discussion 1 08-19-2009 07:56:25 PM
