Rumely 2040 G Restoration
this thread has 57 replies and has been viewed 9865 times
Old 12-07-2016, 05:02:23 PM
lukeste lukeste is offline
Images: 1
Default Re: Rumely 2040 G Restoration
plowing at rollag. it was pulling like a bitch, and running strait gas.... got her too hot. lesson learned I guess.
The Following 3 Users Say Thank You to lukeste For This Post:
Old 12-08-2016, 12:11:45 AM
halcon halcon is offline
Luke, those oilpulls should run cooler on gas than kerosene. I think there is an other issue there if it is actually over heating. Frequently the hub in the cooling pump impeller is worn loose on the shaft, most of them are just cast of aluminum and soon Quit driving when they come loose and of course you loose circulation. An other issue that crops up is often the pipes to the radiator are cut too short and over the years a lot of packing gets forced into the fittings and radiator spacing rings till it plugs them off. Of course pistons fit with out enough clearance will score. Just some more home work for you
The Following 5 Users Say Thank You to halcon For This Post:
Old 12-08-2016, 07:07:36 AM
Dan thomas Dan thomas is offline
Darn I missed the plowing on the g. But glad I wasn't plowing when piston scored.it looked like the ground was a little wet to plow. Looks like a busy winter for you
Dan. Ps really nice meeting you and your family at rollag.
Old 12-08-2016, 09:01:08 AM
Should reword this to read, "Those Oilpulls can still operate on gasoline when the engine happens to be cooler. Operating on kerosene will not cause the engine to operate hotter." If some of the kerosene didn't burn, it could provide some slight lubrication.
Old 12-08-2016, 10:01:53 AM
I stand by the original wording of my post.
The Following 3 Users Say Thank You to halcon For This Post:
Old 12-08-2016, 10:51:46 AM
Wayne Riedlinger Wayne Riedlinger is offline
Ive ran a 20-40 lots with straight regular gas and it run nice and clean. Only issue I have is I had to bypass the fuel line around the heater in the exhaust or the gas would boil coming into the mixer. I think unburned or partially burned kerosene would cause carbon. The impeller on my oilpull came loose years ago if I remember correctly it just had a pin through it. I put a bolt and locknut on and been good ever since.
The Following User Says Thank You to Wayne Riedlinger For This Post:
Old 12-08-2016, 12:30:13 PM
We had an impeller come loose like that on an Heider C also and of course it caused overheating.
---------- Post added at 12:30:13 PM ---------- Previous post was at 12:16:39 PM ----------
Halcon;
I was referring to your first sentence only on my suggested reword. Other portion, I agree. Sorry about misunderstanding. Ed
Old 12-08-2016, 11:30:18 PM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
Timing out will cause an engine to run hot.
Old 12-14-2016, 02:01:04 PM
Images: 1
I got the motor off of the cribbed boards. I made a steel frame to set the motor on and set her down. the way the plumbing is on the bottom is simple but complicated to disconnect. there is a jam nut on the right jug that needs to be loosened, then you thread the cross pipe out to loosen from left jug elbow, and threads further into the right elbow, when threaded out enough then you can take off the left and right jug. uffda, a good flange mount would be a lot handier..
jugs are going off with pistons to get sleeved, pistons will be turned down to match the sleeves.
Name:	2040 motor 2.jpg
ID:	270249   Click image for larger version
Name:	2040 motor.jpg
Old 01-08-2017, 11:37:28 PM
Images: 1
The jugs ar in the boring bars now. Each side will be sleeved. They will be dry press fit in. The pistons will be cleaned up in lathe and address ring lands at that time.
ID:	272006   Click image for larger version
Rumely 12-20 Restoration lukeste Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 140 10-11-2015 10:58:44 PM
Restoration of Rumely # 6153 Jerred Ruble Steam Stationary Engines, Traction Engines, Steam Boats 25 10-22-2013 09:47:29 AM
WDM 16-30 Model H Rumely Restoration Western Development Museum Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 10-31-2012 10:24:08 PM
Rumely 30-60E-restoration help required.... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-27-2011 11:54:37 PM
Rumely 25-40X Restoration, need parts Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-07-2010 06:11:34 PM
