Rumely 2040 G Restoration
this thread has 57 replies and has been viewed 9864 times
Old 09-18-2018, 09:01:57 AM
Sunnybrook Sunnybrook is online now
Default Re: Rumely 2040 G Restoration
That is the same color on mine with a dark oxblood red wheels, I really like it better than lighter.
Old 09-18-2018, 09:53:42 AM
Originally Posted by S.Simons View Post
When do you want to start on my G ?
That one looks good as is
Old 09-23-2018, 09:07:29 PM
lukeste lukeste is offline
Images: 1
Today I blasted another handful of parts and got ready. Eli helped paint the high temp black.
ID:	319407   Click image for larger version
ID:	319408   Click image for larger version
ID:	319409   Click image for larger version
Old 10-08-2018, 11:39:57 PM
S.Simons S.Simons is offline
Nice progress, before this thread goes too far away, what mag was used on the 20-40 G, the one on my G has disappeared ?
Old 10-09-2018, 09:08:22 AM
Jon Nessel's Avatar
Jon Nessel Jon Nessel is offline
All 3 small heavyweights used the Bosch DU2 didn't they? Some had a manual impulse, while others had the auto impulse coupling.
The Following 4 Users Say Thank You to Jon Nessel For This Post:
  #36
Old 10-09-2018, 03:57:30 PM
Images: 1
du2 is correct, and that is what this one has on it. however, the du4,2 is a better mag for the application.
The Following User Says Thank You to lukeste For This Post:
  #37
Old 10-09-2018, 06:13:04 PM
What would a person do with a broken exhaust pipe close to the head on the right side ?
The Following User Says Thank You to S.Simons For This Post:
  #38
Old 11-02-2018, 06:39:32 PM
Images: 1
The fenders are quite rotten, so they got all torn apart. Will make all new fenders with original angle iron. Because this tractor had been painted with a latex paint, great care is being taken to sandblast every part down to white metal. The left fender had a home made took box which was well made, that will go back onto the new fender.
In an unrelated topic but related, rollag will be hosting rumely expo 2022..
The Following 3 Users Say Thank You to lukeste For This Post:
  #39
Old 11-04-2018, 10:55:35 PM
Images: 1
Sand blasting over the weekend. Plan for cab corners and fenders is to paint them disassembled, then hot rivet, and then scuff and paint as an assembled unit. That way the covered surfaces all have good paint in between overlaps.
ID:	322141   Click image for larger version
The Following 4 Users Say Thank You to lukeste For This Post:
  #40
Old 11-16-2018, 04:58:35 PM
Images: 1
Smile Re: Rumely 2040 G Restoration
More pretty parts, the stack has a lot of pitting, but has been smoothed out. Maybe fenders next week
ID:	322992   Click image for larger version
ID:	322993   Click image for larger version
ID:	322994   Click image for larger version
Rumely 12-20 Restoration lukeste Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 140 10-11-2015 10:58:44 PM
Restoration of Rumely # 6153 Jerred Ruble Steam Stationary Engines, Traction Engines, Steam Boats 25 10-22-2013 09:47:29 AM
WDM 16-30 Model H Rumely Restoration Western Development Museum Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 10-31-2012 10:24:08 PM
Rumely 30-60E-restoration help required.... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-27-2011 11:54:37 PM
Rumely 25-40X Restoration, need parts Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-07-2010 06:11:34 PM
