Rumely 2040 G Restoration
this thread has 57 replies and has been viewed 9833 times
Old 12-22-2018, 10:11:25 AM
lukeste lukeste is offline
Images: 1
Default Re: Rumely 2040 G Restoration
Both fenders are done now and looking sharp. For that plow I have been working on fresh casting for machining as well.
ID:	324899   Click image for larger version
ID:	324900   Click image for larger version
ID:	324901   Click image for larger version
Old 12-23-2018, 07:50:12 PM
Images: 1
Many of the spokes were welded to the rim....more than I thought. So for a couple days not I have been blowing out the rivets and grinding out the welds. Almost have 1 wheel ready for new rivets. I did get a big slug of plow parts ready for the 6 bottom
ID:	325002   Click image for larger version
ID:	325003   Click image for larger version
Old 12-24-2018, 12:28:13 AM
Why had the spokes been welded? If there is a gap between the "T" head and the rim, it should not be forced closed by bolting tight which would stress the parts. It's better to shim between the "T" head and the rim and then rivet it tight.
The Following User Says Thank You to Oilpulled For This Post:
  #54
Old 12-24-2018, 05:32:59 PM
Images: 1
The the outer rim side the rivets had corroded and caused the rivets to loosen on wheel side the way it looks. So a previous owner must have had a welder and did what he needed to do to keep it going. I did have 1 spoke that will need a shim in between the foot of the spoke and the rim. All the rest are very tight.
The Following 2 Users Say Thank You to lukeste For This Post:
  #55
Old 12-29-2018, 07:40:38 PM
Images: 1
Been working on the other rear wheel which has been a flat out sob. The spokes were welded on the inside and rivets welded on the outside. This has pretty much been a real prick of a wheel. Murphys law made sure I ran out of oxygen on a saturday night the wheel face rivets for combining the ends together will be getting all new rivets too. Th hi s Al's oi had a couple loose ones on the hub. I color coded the spokes... yellow is tight. Green will need a shim.
ID:	325380   Click image for larger version
The Following 11 Users Say Thank You to lukeste For This Post:
  #56
Old 12-30-2018, 01:00:24 PM
Mark Schleppi Mark Schleppi is offline
Luke:
Isn’t it amazing how many little things matter when you want a tractor to work instead of just run? Good job MSS
The Following 2 Users Say Thank You to Mark Schleppi For This Post:
  #57
Old 12-30-2018, 03:20:49 PM
halcon halcon is offline
One other option to consider Luke, is to remove the hub rivets on a spoke and build up the end where it buts against the hub then fill in the rivet holes and repunch or drill them. The spoke should then wedge in tight.
The Following 2 Users Say Thank You to halcon For This Post:
  #58
Old 01-01-2019, 06:01:14 PM
Images: 1
I got last rivets cut out of the last wheel today. So since that is about it for that at this time, I got back on the gang plow drilling holes in 2 new beams I had made. Bridgeport is new to the shop and is very nice for drilling big holes on these heavy pieces
Rumely 12-20 Restoration lukeste Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 140 10-11-2015 10:58:44 PM
Restoration of Rumely # 6153 Jerred Ruble Steam Stationary Engines, Traction Engines, Steam Boats 25 10-22-2013 09:47:29 AM
WDM 16-30 Model H Rumely Restoration Western Development Museum Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 10-31-2012 10:24:08 PM
Rumely 30-60E-restoration help required.... jim burlingham Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-27-2011 11:54:37 PM
Rumely 25-40X Restoration, need parts Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-07-2010 06:11:34 PM
