Rumely Y Questions
this thread has 32 replies and has been viewed 4363 times
Old 08-16-2017, 08:28:16 AM
Old Iron Dave Old Iron Dave is offline
Default Re: Rumely Y Questions
I had removed the sleeves and had them bored, sleeved then re-bored back to original size. I then reinstalled them using the original felt seals. After they were installed I applied the RTV silicone as described in post #8.
Old 08-16-2017, 10:19:28 PM
Keith Kinney's Avatar
Keith Kinney Keith Kinney is offline
What type of O rings did you use. Round or square or ???
Keith Kinney
www.HerculesEngines.com
Old 04-08-2018, 10:23:38 PM
Weld Engineer Weld Engineer is offline
I think I found the oil leak culprit. Seals are a bit crusty but this pit at the 7 oclock looks like a great place to leak. Laundry list of things to do while it is tore down. I plan to use square rubber Viton o ring
ID:	307721   Click image for larger version
Old 04-09-2018, 08:59:13 AM
Ellis Wellman Ellis Wellman is offline
Standard round cross section.
Old 05-19-2018, 09:22:40 PM
Upon further inspection I have a cracked sleeve.
Working on rebuilding the head it's getting new valves, valve guides springs, valve seats and surfacing. It came back with a no crack bill of health. I was cleaning the sleeves up tonight while I wait for progress on the head.
Chances of running this summer just dropped by about 75%.
I've had sleeves made by power bore/ Quaker castings in Ohio they do nice work. Not sure if they can do one this big. Find out next week. Where else does one go for a large sleeve?
At least I know where the oil is leaking in now.
Old 08-27-2018, 09:32:20 PM
Stage 1
The head is coming together nicely
New valves from H&J Machining - beauties
New valve guides cast from a pattern and machined from Leroy Machine - very nice
New springs from Leroy
Valve seats ground and surfaced by C&P Machine
Sleeve work is in progress Ill report on that when I get them back.
Thanks Craig for the occasional phone a friend
ID:	317277   Click image for larger version
ID:	317278   Click image for larger version
The Following 8 Users Say Thank You to Weld Engineer For This Post:
Old 09-10-2018, 10:46:11 PM
Stage 2.
I made the trek out to Andover to see the 150 Case this weekend. Lots of driving but worth it. As I promised Craig - photos of the sleeves Henry sleeved for me. Came out great pistons checked out fine so he polished them up a bit and turned just the top groove. I have new rings from Dave at Otto gas engine and spacers. I only need spacers for the top groove so I have extras. Ray Slabaugh already put oil rings in during the year he had it so Im reusing them per Daves advice. They were barely used. A lot more to this story its a sentimental journey that makes me miss my grandfather but 30 years later it will finally be fixed and no longer blow oil or fill the crankcase up. I got the head assembled too. Hopefully by next Spring have it all back together.
Henry at H&J did a great job!
ID:	318474   Click image for larger version
ID:	318475   Click image for larger version
ID:	318477   Click image for larger version
The Following 7 Users Say Thank You to Weld Engineer For This Post:
Old 11-25-2018, 11:14:44 PM
Made my O-rings and pressed the sleeves in today with a porta-power went in nice and .060-.070 of bounce back on my square cord o-rings so Im pretty confident it will seal up nice. I used 5/16 and 1/4 square Viton cord stacked together the thicker cord went on the sleeve first. Pistons and head up next in a few weeks.
Im also working on the carburetor did the pump plungers ever have springs for the check balls or just gravity seal?
ID:	323507   Click image for larger version
The Following 6 Users Say Thank You to Weld Engineer For This Post:
Old 11-25-2018, 11:25:12 PM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
Images: 4
Just gravity, there isn't much room in there and the check balls only lift off the seats a very little.
Old 11-25-2018, 11:39:31 PM
Id like to put new balls in which should I use brass or steel? I want to have the water side working and the ball was missing in that plunger.
Rumely Oil Pull Questions William Frels Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 07-09-2014 10:00:14 PM
Rumely Questions Jim Gordon Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 04-06-2014 02:00:01 PM
Rumely clutch questions Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 02-12-2013 11:42:21 AM
Rumely 14-28 Questions Steve Webre Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 09-05-2011 07:13:22 PM
Rumely Memorabalia questions krum Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 08-16-2007 12:56:42 PM
