Rumely Y Questions
this thread has 32 replies and has been viewed 4363 times
Old 01-11-2019, 02:44:19 AM
Default Re: Rumely Y Questions
I never used water in any of mine so I took the springs off of the water pump plungers and just let them sit there.
Burning kerosene in an engine that isn't run HOT is self defeating dilutes the crankcase oil and costs more anyway.
The Following 3 Users Say Thank You to Craig A For This Post:
Old 01-11-2019, 09:03:10 AM
Bubbles Bubbles is offline
Originally Posted by Weld Engineer View Post
Working on the carburetor. I found a new set of pumps for it from Gary Biewer mine are worn. Any suggestions on new springs? Pretty corroded and I’d like to replace them on the new pumps. Also a question concerning the two brass “flutes” with the needle valves in them. The fuel one is solid at the end and the water one has split is it supposed to be like that or did it open up an I needed to repair it? It looks like they were slit then brazed/welded back together. I intend to have the carb and fuel system working like original.
Thanks!
The needle seats have a slot cut in them where it goes into the venturi (top of the carb). The slot should be positioned so it is horizontal when fully tightened. The fuel then goes out both sides of the slot and drops down. The end of the slot is soldered.
As for the springs, any spring will do as long as it can return the pump to the up position.
There are small holes/ galleries where the fuel feeds up from the pumping chambers to the needle seats, make sure to clean these out thoroughly.
Make sure the butterfly shaft is not worn and replace the bushings. File the new bushings once they are installed to follow the bore of the carb.
The Following 2 Users Say Thank You to Bubbles For This Post:
  #33
Old 01-11-2019, 09:06:15 AM
Weld Engineer Weld Engineer is offline
Understood. Iím rebuilding it and want it functional in case I want to use it as originally made. I mean donít we all have shops full of non-essential stuff :-).
The Following 3 Users Say Thank You to Weld Engineer For This Post:
Rumely Oil Pull Questions William Frels Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 07-09-2014 10:00:14 PM
Rumely Questions Jim Gordon Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 04-06-2014 02:00:01 PM
Rumely clutch questions Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 02-12-2013 11:42:21 AM
Rumely 14-28 Questions Steve Webre Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 09-05-2011 07:13:22 PM
Rumely Memorabalia questions krum Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 08-16-2007 12:56:42 PM
