Caterpillar 60 Parts Needed
this thread has 7 replies and has been viewed 1411 times
Old 10-21-2017, 02:43:36 PM
Dan Moore Dan Moore is offline
Default Caterpillar 60 Parts Needed
Ive got a Cat 60 that needs a ton of work done to it.Its a 1928 machine. Just wondering who the Cat 60 gurus are . I need a radiator side panel that has sixty on the side. I need the rubber parts that are on the clutch assembly. Going to need some valves,rings,gaskets, 1 piston and much more. SOMEONE HELP STEER ME! thanks
Old 10-21-2017, 04:41:00 PM
Tim Colwell's Avatar
Tim Colwell Tim Colwell is offline
Default Re: Caterpillar 60 Parts Needed
This guy can definitely point you in the right direction.
http://www.antiquecrawlerparts.com/sixty.html
Tim Colwell
JD & IHC corn sheller and engine collector.
The Following User Says Thank You to Tim Colwell For This Post:
Old 10-21-2017, 05:58:01 PM
Ozlander Ozlander is offline
Ask your questions on http://www.acmoc.org/bb/
Old 12-30-2018, 11:42:30 PM
Beth V's Avatar
Beth V Beth V is offline
Bump for Dan.
Old 12-30-2018, 11:46:50 PM
Rick Trotnic Rick Trotnic is online now
Do you still need radiator side panel? I have one , Rick
Old 12-31-2018, 06:16:51 PM
Im looking for 2 of them.
Old 01-01-2019, 08:04:48 PM
Rick,How much do you want for your side panel? Thanks Dan
Old 01-01-2019, 09:23:37 PM
MSimons's Avatar
MSimons MSimons is offline
Card Sponsor
Henry @ H & J Machining can supply the valves. Phone: (701) 652-3289
The Following User Says Thank You to MSimons For This Post:
Caterpillar 20 Parts Needed bocephus_k6 Dozers and Crawlers 18 03-01-2011 11:43:50 PM
help needed B&S parts list needed desotonut1953 Small Air Cooled Gasoline Engines 0 08-31-2010 12:07:38 AM
Caterpillar Magneto parts needed Kelly Barnett Magnetos, Ignition Coils and Spark Plugs 2 08-04-2009 08:18:44 AM
Caterpillar 15 Parts Needed! Reeves1665 Dozers and Crawlers 3 09-12-2007 04:05:33 PM
parts needed Chris1021 Small Air Cooled Gasoline Engines 0 09-04-2005 12:55:22 AM
