New Pioneer Project at Mark's Machine Shop
this thread has 73 replies and has been viewed 11442 times
Old 11-24-2018, 11:56:45 PM
Default Re: New Pioneer Project at Mark's Machine Shop
What is a good source for the laminated shim stock sheets?
Old 11-25-2018, 02:03:35 AM
Eric Best's Avatar
Eric Best Eric Best is offline
Last I bought was from McMaster Carr. It is adhesive laminated, not soldered.
The Following 2 Users Say Thank You to Eric Best For This Post:
  #73
Old 01-02-2019, 07:31:54 PM
It's time for an update.
I mentioned earlier all the valve guides are shot so it was easier to remove the cylinder blocks to remedy the guides.
Under the rear cylinder block a pile of oats was found...….maybe the owner would like to have them back?...….
ID:	325714   Click image for larger version
ID:	325715   Click image for larger version
ID:	325716   Click image for larger version
The Following 11 Users Say Thank You to Craig A For This Post:
  #74
Old 01-02-2019, 07:33:07 PM
Slowly but surely Mark has been fitting the rod bearings.
It's a LOT easier to do with the crank in a lathe...….
1920's or 30's Circus Wagon with small city built inside,Blacksmith Shop,machine shop Jim Martin Scale Model Engineering 2 04-15-2013 11:01:46 AM
Machine Shop Wood Shop Collectors in Michigan and Ohio antiquemachinery Farm + Industrial Antiques and Collectibles 1 03-30-2013 12:12:58 PM
The pioneer red E project darrin Garden Tractors / Mowers / Scooters 25 03-07-2008 10:37:15 AM
Machine Shop Course enginenut Antique Engine Archives 1 02-12-2002 11:05:54 AM
machine shop bill Antique Engine Archives 4 01-06-2002 04:24:59 AM
