Wisconsin Engines
Fairbanks Morse Mag Question
this thread has 4 replies and has been viewed 668 times
Old 06-05-2018, 11:24:52 PM
mjohansson mjohansson is offline
Default Fairbanks Morse Mag Question
Ah the joys of working on things that you have never done before...I have two Fairbanks Morse magnetos, one on a Wisconsin AKN and on a AEN. Now the AKN mag has a red wire coming from the coil and goes to the points. Then a black wire to ground?
The AEN has the red wire BUT the black wire was just attached to the points and the other end taped off not going to any ground point. Is that correct? or does that black wire need to be attached to some kind of ground?
Thanks and God bless.
Old 06-06-2018, 07:54:19 AM
Russell Walker Russell Walker is offline
Default Re: Fairbanks Morse Mag Question
Grounding points is the kill switch.
Old 06-06-2018, 01:51:20 PM
David M. Lyon's Avatar
Images: 32
All the black lead does is go to a kill switch that grounds the points. Just take it off or leave it taped .
Old 06-07-2018, 08:14:08 PM
Ok, thanks a lot. One of the reasons I asked was after installing and setting the points on the AEN's Mag, and I turned it over a few times, I notices sparks form the points! Hmmmm....
Old 06-08-2018, 11:23:03 AM
Images: 32
Ground the high tension (spark plug) terminal to stop it from arcing internally and damaging the coil.
3 HP Fairbanks Morse mag question Bill Antique Gas Engine Discussion 12 02-24-2014 11:22:02 PM
Fairbanks Morse question animals Antique Gas Engine Discussion 11 10-11-2012 10:54:14 AM
Question on Fairbanks Morse Headless cart wheels, and question on Sumter mag Will Batty Antique Gas Engine Discussion 8 06-22-2009 11:34:36 PM
Fairbanks Morse Question? Bendel Clack Antique Engine Archives 5 07-14-2002 10:16:30 PM
Fairbanks Morse Question trbailey Antique Engine Archives 4 06-29-2002 04:30:00 PM
